Olevia 337-b11 no dc
    Re: Olevia 337-b11 no dc
    That doesn't make sense, why would they do that?
    • freakaftr8
      • Oct 2012
      • 3743
      Through a series of bridges on the circuit board. I have to be overlooking something. All the output pins on the secondary side of the transformers are also shorted to ground
        On the secondary windings, one end of each winding will be tied to cold side circuit ground, the other end of the winding will feed the Anode side of the rectifier diode, so yes, you will read very low DCR (DC resistance) of the winding.
        At this point with the power supply by itself and you force on the PS_ON pin and the result is that you still do not have PFC voltage booster working, you need to find out if the PFC Controller IC is getting the voltage at its VCC pin.
        • freakaftr8
          • Oct 2012
          • 3743
          On my pictures which one would that be. I still have 18v shorted to ground though
          • freakaftr8
            • Oct 2012
            • 3743
            If you cannot tell I usually ace with board repairs but when it comes to power supplies for some reason if it's not the usual mosfet failure or a diode here or there I'm lost...
              Can I see the pictures of that 18v section, both side of the board?
                The PFC controller and SMPS circuit is the small circuit board sitting vertically with 8 pins on it, close to the bridge rectifier.
                  I look at this thread:
                  https://www.badcaps.net/forum/showth...Olevia+337-B11
                  Which I redlined the board, I do not see 18V power supply.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Bud you are the man. Thanks. The 18v is here.
                    http://1.bp.blogspot.com/-PDAkne26cG...-237-T11-2.jpg
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      All other voltages show at least 1k ohm to ground. The 18v is 1 ohm. Definitely an issue.
                        https://www.badcaps.net/forum/attach...7&d=1363927087
                        As you can see, you can see the connection from the center pin of the 12V rectifier that flows through those red lines, you can lift off the inductor or jumper of that path to see if the short will go away. That will be the way to isolate the short. The rectifier can also be shorted out which needs to be checked. There is also small SMD cap C39 on the 12v and Gnd.
                        There is no sign that some one had replaced that rectifier for 12V and put in one that does not have Isolated tab?
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Ok that 12 rectifier is a diode. It measures shorted all across the 3 legs only on the board. I pulled it and it's not shorted. The short is on the board it seems
                            So it's still reading short with the diode removed? Then next step is to remove the jumpers, inductor in the path to the connector.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              I just looked at a delta power supply out of a sanyo. Similar setup. I get 365 ohms to ground on 12v side. 24v high like 26kohms.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Ok I removed the inductor after the rectifier and no more short.
                                However still no success. This boards cheap enough I may just order another and pin out this board and try to find the issue between measurements between the two
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  I'm measuring -14.8vdc at the vcc pin of the pfc ic on the stand up board of course ground is measured of the ground pan of the PFC IC
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    If my bridge rectifier is bad would I still have 5V stand by?
                                      The 5VSTBY is an always on power supply, meaning it is on and running the minute you plug the power cord into the AC outlet, the 12V (18V?) and 24V are switched power supply which will come on when PS_ON signal is applied to the board.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        well I just picked up a new power supply for this TV brand new OEM sound deal on it for 20 dollars. So I do some measurements test connected together and powered on and I get the Olivia flash screen but then as soon as it goes to a darker picture the backlight start flickering like crazy. The only way to get the back lights from flickering is to have an all white screen now I know this sounds unusual but as soon as there is anything displayed besides white it gets the backlight start flickering again I checked both of us I've got no change between when its flickering in when it is flickering except for the 24 volt DC out to the inverters that starts jumping between 22 and 24 volt. Now if I disconnect a slave inverter I have a solid 24 volt but of course I do not have a picture. I was doing some studying on this particular set up and one person had the same issue and they replace the t-con board which fixed it there is a 3-pin ribbon that goes from the tcon to the master inverter. but I can remove the LVDS from tee time and I still have a flickering background. only with both inverters connected at the same time do I get the flickering
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          after much diagnosing I have a feeling that there's something wrong in the primary inverter. When powered up the Olivia flash screen which is white shows perfect no flickering but as soon as the screen gets to a darker image the backlight start to Flicker. I can connect my laptop and as soon as I open Internet Explorer the screen shows white which causes the backlights not the Flicker anymore. I've tried heating up the inverters and cooling inverters to no avail. The 24 volt output of the power supply when this is happening likes to very and I hear settle clicking sound from the primary inverter the blue light on the inverter coincidence with a ticking sound coming from the primary inverter. I don't believe it's a power supply issue if I disconnect both inverters I get a solid 24 volts. If I disconnect either inverter leaving one connected I still get a solid 24 volts but as soon as both inverters are in circuit the backlight starts to Flickr unless it's an all white screen.
                                          • Francesc V.
                                            Bitfenix Whisper 850W - Only 5VStby and PSON
                                            by Francesc V.
                                            Hi:
                                            I am trying to repair this modular ATX PSU. It only has the 5V Standby and PSON enabled (3.33V).
                                            PSON is delivered by (ST9S429-PG14) in pin4. This chip is a Voltage controller but it doesn't seem to trigger any PWM signal to pass it to primary through coils and "move" the big mosfets. Also next to it there is a EST7618 that it also seems a voltage controller.
                                            Not sure if in the right direction, but trying to find where PWM signal is generated.
                                            Green section seems that could be the "PWM section". It's driven by a...
                                            11-27-2023, 05:18 AM
                                          • cadar21
                                            olevia - 747i-B11 fw
                                            by cadar21
                                            hi guys looking for a FW UPDATE FOR MY oLEVIA 47'..
                                            the screen is freezing an the audio continues to play...
                                            my current fw is
                                            --FRW--747-B11_V63.7.5A17 VLCD78310263
                                            if that helps...my research leads nowhere...i guess the website is no longer available since Olevia filed for banckrupcty....
                                            any help would be appreciated.. looking for the USB fw..
                                            Olevia - 747-B11
                                            FM1-04700E-S00
                                            12-13-2017, 03:13 PM
                                          • hispeck
                                            Olevia Tv Lt23hvx service manual
                                            by hispeck
                                            Hello all, I need help on olevia tv service manual. The model Lt23hvx
                                            12-03-2018, 05:12 AM
                                          • Michale32086
                                            THE HULK Olevia 265TFHD 65" LCD Inverter Boards ???
                                            by Michale32086
                                            Got in a monster.. Older Olevia 65" LED and the thing weighs like 500 lbs!!
                                            OK, OK, only 235 lbs but it feels like 500...
                                            Power it up and, after a few tries, it comes on.. No backlight on the left side of the screen, as you face it..
                                            So I am thinking bad inverters.. It's a set of 3 on either side..
                                            Ordered a replacement set, but they came in damaged.. Specifically, the metal frame that surrounds the doo-hickeys.. (see pics)
                                            Would that affect functionality??
                                            Thanx...
                                            07-31-2018, 06:38 AM
                                          • m041633n
                                            GDM50 LA-L241P Rev 1.0 - 2 Amber and 7 White Led Fix Needed
                                            by m041633n
                                            Hello Everyone!
                                            I would like to know the Jumper location for the 2 Amber 7 White Led Blink Code error. According to Dell 2,7 Led codes are for display or the Display cable failure. I didn't changed the display nor the cable. The issue happens only when restarting the machine from windows and from the BIOS. And when opening and closing the lid the display turns off and never turns back on. But the machine is working! I confirmed it by pressing the CAPS Lock key. Does anybody has this issue and fixed it by jumpering some fet near the display connector on the motherboard. If So Please Help...
                                            03-31-2025, 08:35 AM
