Acer a515-52g no power 19v not passing through first mosfet
  • Kshi
    • Aug 2024
    • 20
    • Philippines
    I purchased this laptop from fb marketplace
    and the previous tech jumped 1st mosfet. maybe it got fix, then time comes by jumpering fried the charging ic?
    tried to change mosfet but it does nothing 19v is not passing through 1st mosfet
    tried to jumper again, I got 5vlp and 3vlp but 5valw and 3valw is missing
    I suspect that the charging ic is bad? If so how do i test if it is bad.
    Cant see any short or corrosions on board
    schematic and brd view attached below
  • Senaku
    • Aug 2025
    • Chile
    Hola estimado.
    Empieza revisando el PU301 que es el que controla todo el encendido.
    Revisa la pata 1 ACIN, para 30 ASGATE que es el encargado de dar el pulso para apertura de mosfet.
    El KBC revisa que le lleguen los 3.3v.
    Mide las fuentes de 3.3 y 5v.
    No digas puenteando los mosfet ya que el voltaje lo estás induciendo al micro.
    Mide los mosfet para detectar algún cortocircuito, por lo que parece es un problema de corto.
      • 21841
      Originally posted by Senaku
      Hola estimado.
      Please type in English !
      • ipn00tic
        Acer vx5-591G I removed Mosfet and it works without it?! could it cause problem?
        by ipn00tic
        Hello everybody,
        I'm learning alone at home (with you) of course.
        I have an Acer VX5-591G laptop that was given to me as scrap where I was training and diagnosing.
        The Laptop turns on and starts to boot for a few seconds but before displaying any image it short circuits the main 19V power supply and turns off.
        I managed to "repair" the laptop and it turns on and everything works, I even did game tests for the CPU and GPU and everything works but what I did was remove a Mosfet (PQ807) from the VCC_GT power supply.
        The VCC_GT power...
        03-01-2024, 05:32 AM
      • jermac0711
        ACER PEW71 LA-5894P CPU_B+ MOSFET NEED HEPL
        by jermac0711
        Brand : Acer
        MOBO: PEW71 LA-5894P
        Issue: initially no power. PQ73 mosfet is busted. (AO4466) . Unit has power now but PQ87 is heating up too much (observerd under thermal camera) causing to shut down the system. I tried to remove the removable CPU and the mosfet temperature went normal. I have a replacement CPU from same model but everytime there's a CPU, mosfet PQ87 temperature is rising rapidly.
        I hope you guys can shed some light. Thank you so much in advance.
        12-17-2024, 08:25 PM
        09-06-2024, 05:27 AM
      • vexarvf1s
        Acer: No power after first MOSFET no short? Looking for guidance.
        by vexarvf1s
        Looking for guidance in tracking down missing main power rail.
        I have an Acer that I am working on. It runs on the battery, but does not charge. I changed the power adapter and same thing battey not charging, and continues to discharge. So I opened the computer and started looking for the problem to fix.
        First thing I checked is if the power form the charger is getting to the mainboard. I found that 19V is going all the way to the first MOSFET. So DC jack is fine. However I do not have power past the first MOSFET.
        So checked for voltage on the gate of the first MOSFET and...
        05-13-2023, 07:55 AM
        Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
        This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
        09-07-2024, 05:00 AM
