jvc lt49c862 firmware needed (I think)
  • Chrissygizmo
    • Mar 2021
    • 145
    Hi all, ive been asked to repair a jvc lt49c862 , basically when I switch it on it lights up (blueish so it needs backlights replacing) the jvc logo appears then it goes off again but all the while the standby light continues to flash constantly, i tried changing the main board to one from the same model tv but it didn't work at all so I'm guessing that board is broken, I would be grateful if anyone could point me in the right direction...
    Thank you in advance
  • Bholu
    • 48
    • Saudi Arabia
    I think hear u will find the firmware for free.(https://receiverpro.net/jvc-led-tv-s...-download/)may be it will help u.but I think u have faulty panel scaler pcb check may be there any short circuit or broken part.
    • Chrissygizmo
      • Mar 2021
      • 145
      I've just checked that link you sent but it comes up as 404 PAGE NOT FOUND
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        seems like a common issue JVC LT-49C862 Smart TV won't load | Tech Support Forum​
        • Diah
          • Feb 2013
          • 6496
          first be sure the leds BL are fine.... seconds write the mainboards label 17MB ????
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            Looking at picture 6 i think its a 17mb120
            • Daniel Larsson
              Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
              by Daniel Larsson
              My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
              I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
              During these seconds the function button is not working...
              08-13-2025, 10:29 AM
            • EduCabral
              [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
              by EduCabral
              I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
              While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
              šŸ”§ Details:
              • Model: YT-M06
              • Interface: Pioneer 1
              • MCU: Fujitsu MB89F202
              • Goal: Find a valid .bin firmware file or memory dump from a working unit
              I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
              07-15-2025, 12:26 AM
            • Daniel Larsson
              Firmware file for Marantz NR1501 needed
              by Daniel Larsson
              I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
              After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
              The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
              The content of these seems to be useless as far...
              05-23-2025, 04:11 AM
            • jorpec
              Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
              by jorpec
              Hi, all
              I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
              10-17-2025, 03:51 AM
            • Robby-Gr
              TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
              by Robby-Gr
              I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
              However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
              The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
              Additional issues:...
              09-27-2025, 12:02 AM
