LG50PG20D Plasma which not showing picture but has sound!
  • wezzo
    • Jan 2014
    • 13
    • australia
    Hi Guys,
    First and foremost thank you for sharing such great knowledge..
    i have been given an LG50PG20D Plasma which is not showing any picture but has sound!
    I have researched quite a bit and have done some tests on the Plasma which are below.....
    I have removed the cover and cleaned dust with compressed air.
    All tests where completed with wrist strap.
    Power up shows Red Standby LED on front panel
    Green middle LED on control board.
    When press power on Remote Green Front LED flashes 6 times and stays solid Green
    Can scroll through inputs on remote and get dvd sound through to speakers
    Fuse ok on PCB and heat syncs are all warm after 30 mins.
    Fuse ok on ZSUS and heat syncs are all warm after 30 mins.
    Fuse ok on YSUS but heat syncs are cold after 30 mins.
    No bulging caps or signs of burnt smell.
    The outputs of the Va & Vs are as follows... Va: 60 shows: 60.6 - Vs:194 shows: 194.5
    Isolated PS and Have done a static load light bulb test on it for 15 min and all voltages good
    I have isolated the Control board and checked FL111 and FL12 all good
    I also connected 5v from power supply to IC121 pin 1 and all good as i can tell, middle lcd lights up.
    Checked IC 121/151/171 and all seem fine
    Checked 16v to ZSUS from pin 1 on P163 and all good
    Then isolated Main PWD, shorted the auto test pins but no test pattern.
    That's where I'm up to.
    Does this mean its either of the Y/Z or X boards or Screen?
    Any help would be greatly appreciated.
    Thanks in advance.
  • wezzo
    • Jan 2014
    • 13
    • australia
    Re: LG50PG20D Plasma which not showing picture but has sound!
    here are the pics of the boards while powered ...
      On the back inner metal plate that all the circuit boards are mounted on, there should be a sticker, printed "MODEL: PDP50######" (or similar...) what is printed on yours?
      • wezzo
        • Jan 2014
        • 13
        • australia
        Hi Tom66, thank you for the quick reply, the Model no is PDP50G10343, attached are the pics of it.
        • erskine
          • Jan 2014
          • 20
          • barbados
          hi Wezzo, had a similar set with the same problem , it wasthe ysus board
          • wezzo
            • Jan 2014
            • 13
            • australia
            Het Erskine, i am thinking that too but want to make sure its nothing else as well, how much was the YSUS to replace mate?
            • wezzo
              • Jan 2014
              • 13
              • australia
              Does anyone else think its the Y-SUS or know of a way to pinpoint it properly
                50G1 in this document.
                Check -Vy, Vsc per instructions.
                • wezzo
                  • Jan 2014
                  • 13
                  • australia
                  Thanks Tom, -Vy is -.2 and Vsc was 0
                  does that mean Ysus board has gone?
                  • wezzo
                    • Jan 2014
                    • 13
                    • australia
                    i just had another look at the upper and lower buffer boards, i read somewhere that the correct way to disconnect them was from the Ysus board itself and not the panel, so i did that and...
                    Disconnecting the upper buffer with center cable attached = unrecognizable picture on top and white/grey screen on bottom which fades to dull grey
                    Disconnecting the upper buffer with centre cable pulled = only white/grey screen on bottom which fades to dull grey, heat sinks on upper buffer got extremely hot and YSus heatsinks got warm for the first time.
                    Disconnecting Lower Buffer with centre cable attached or pulled = NOTHING
                    i completely removed upper buffer and re tested the -Vy and Vsc and both fluctuate between 0 and 46v.
                    plugged a dvd player in and got a very garbled lower picture for a few seconds then tv switches into standby, turn tv back on and white/grey screen again, no garbled picture?
                    any suggestions anyone? Ysus plus upper Buffer??
                    any help would be awesome
                    • wezzo
                      • Jan 2014
                      • 13
                      • australia
                      anyone please?
                      • wezzo
                        • Jan 2014
                        • 13
                        • australia
                        could anyone please tell me if it is the Ysus board where i could purchase this from?
                          Does -Vy, Vsc appear if buffer disconnected? Y-sustain fuse good?
                          • wezzo
                            • Jan 2014
                            • 13
                            • australia
                            thank you Tom,
                            -Vy and Vsc are the same with both buffer boards disconnected (reading fluctuate between 0 and 46v) Fuse is all good (measures 194.4 on both side and diode test with power off the continuity is good)
                              Bad Y-sustain with possibly buffer boards having damaged it, though that is rare nowadays.
                              • wezzo
                                • Jan 2014
                                • 13
                                • australia
                                cool thank you again, should i get buffers as well do you think?
                                • wezzo
                                  • Jan 2014
                                  • 13
                                  • australia
                                  i just checked the upper buffer and according to the lg 5050pg20 training slides the upper buffer is stuffed! but lower checked out ok
                                  • HENFOR
                                    • Aug 2014
                                    Disconnect the power from the mainboard the board down on the right hand side.
                                    now short out the auto_gen with a peice of wire while tv unplugged.
                                    after this process plug it in.
                                    You should see a test pattern this will rule out Y-sus and Z-sus problems.
                                    Problem will be main board
                                    • rccrasher65
                                      • Mar 2014
                                      • 620
                                      I had the same tv, mine was upper buffer board, please be careful removing ribbon cables I tore mine and ruined the set over a $19.00 board. shopJimmy. com great place for boards.
                                      • gravybones2002
                                        • Feb 2015
                                        Re: LG PDP50G10343 which not showing picture, at all
                                        Hi guys
                                        I have myself a LG PDP50G10343, I have had the same issue as the previous people on this forum and have also performed the same tests as everyone else, I still haven't gotten any success, I say my problem is pointing towards the main control board for the X and Y sustain (50G1A_CTRL) (EBR50038701) has anyone replaced this to fix the issue
                                        Please help...... thanks
                                        • KYBOSH
                                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                          by KYBOSH
                                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                          No picture but you hear the TV static (white noise) playing loud and clear.
                                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                          But it seems they didn't get too far and just left it.
                                          When I first took a look I was amazed at how pristine the inside looked.
                                          Its as if the TV had been in a time capsule.
                                          Caps looked like they were just pulled off the self.
                                          Copper coils had no sign of corrosion on...
                                          02-01-2023, 11:10 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
