Sony XBR-49X800G networking issues
  • HarryZ
    • Jan 2024
    • 9
    Aloha. First post here, hope I can find someone to assist me.
    I have a Sony XBR49X800G with streaming issues. The issue mostly occurs watching sporting events (basketball and football). The picture will sometimes get pixelated, sometimes freeze for a few seconds while the audio continues, sometimes it's jerky. In other words, you get a headache watching the TV.
    My ISP provides 500 Mb service and I have verified that I have at least 500 Mb on ethernet, and something over 300Mb on WiFi. I installed Analiti on the TV (it's an Android TV) and I get ~ 70 Mb on both WiFi and Ethernet connections. I'm assuming this indicates an issue with the networking card. Looking for replacement parts I did find some network cards / modules supposedly for this TV. So, I'd like to try replacing this module. But, I cannot find a service manual for this TV. Can anyone point me to a service manual? Or, would you be willing to walk me through the process here on the forum? I fix computers so I'm familiar with proper procedures, but have no idea how to take this thing apart.
    Mahalo, Harry Z
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    With certain tvs freezing and issues with that is a main board issue, maybe see other replies but can be problem. I don't have service manual for this one but you may want to look into the problem being your main board and not actually the Wi-Fi chip. Not to say that it wouldn't be the Wi-Fi chip but freezing you can definitely be the main board. Just a suggestion
    • kasfamily
      • Aug 2014
      • 774
      • Russia
      Hi, check the firmware version of your TV
      https://www.sony.com/electronics/sup...m_source=glean
        • 12328
        • U.S.
        Something is peculiar with those numbers, what model router do you have, whole model number, it doesn't look like you are getting what you should but 70 is plenty and should not cause the distortion.
        • HarryZ
          • Jan 2024
          • 9
          Aloha @EasyBone. Thanx for the info. Any hints on how to determine if it's the main board or the network card?
          • HarryZ
            • Jan 2024
            • 9
            Great suggestion. I had not considered this as the TV is supposed to notify my when there is an update available. But, it did not. Installing the latest update as I'm typing this.
            • HarryZ
              • Jan 2024
              • 9
              Yes, I thought they were strange numbers, too. But I read something in a different forum that most TVs have a 10/100 networking card in them, so I shouldn't expect to see high speeds. Can you verify this?
              FWIW, the modem is a EMG3415-B10A.
                • 12328
                • U.S.
                Ah ok, that makes sense, seems like you should be getting about 100, sometimes my speeds slow down and a reboot of the modem and router bring it back up.
                • HarryZ
                  • Jan 2024
                  • 9
                  If I unplug the ethernet cable from the TV and plug it into my laptop, I get over 500 Mb, so it's not the router.
                    • 12328
                    • U.S.
                    Well do you get the problem when using just the ethernet connection.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      70Mbps is the real world speed on a 100Mbps connection.
                      Where are you streaming from ?
                      4k streams are usually between 15Mbps and 30Mbps.
                        • 12328
                        • U.S.
                        I get 103mb over wifi from router to my steaming box.
                        • HarryZ
                          • Jan 2024
                          • 9
                          I have updated the firmware. Problem is still there
                          • HarryZ
                            • Jan 2024
                            • 9
                            Yes
                            • HarryZ
                              • Jan 2024
                              • 9
                              I'm not sure what you mean by "where are you streaming from?" If this is supposed to mean what streaming service am I using, then HULU is the worst offender. Paramount+ also has issues.
                              And if 15 - 30 Mbps is supposed to be "good", then maybe it's time for a new TV.
                                • 12328
                                • U.S.
                                Originally posted by HarryZ
                                Yes
                                Ok, so it's not the wifi at fault.
                                  • 12328
                                  • U.S.
                                  If you have the setting and haven't tried it, choose cinema or movie mode for watching sports, that may help, probably best to turn off any other so called picture enhancements, they usually don't help the picture anyway.
                                  • EazyBone
                                    • Jun 2023
                                    • 1362
                                    • United states
                                    I still think main part is culprit. But yes 15-30 mbps should be fine. This is just hunch on my part. I hate repairing sonys personally lol. They make things so complicated for no reason
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      Not all streaming sources are a service, I picked my words intentionally.
                                      If you had taken the back off your TV you would see that the WLAN/BT card and LAN socket both connect to the main processor.
                                      • HarryZ
                                        • Jan 2024
                                        • 9
                                        Aloha diif. Well, if I had been able to locate a repair manual with instructions on how to take off the back panel, I would have. It seems moot now that I know that ~ 70 Mbps should be more than enough for non-jumpy streaming. Would you agree that the more likely culprit in my case would be something other than the networking cards?
                                        Mahalo, Harry Z
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • PontyPCs
                                          Sony Android TVs eMMC Issues
                                          by PontyPCs
                                          Hi people.
                                          I have been trying to get my head round these issues with the eMMC putting the TV in to a boot loop condition, or completely dead, when a dump of the Boot 1, Boot 2 and USERDATA partitions have been made, the MLC lifetime counter has been reset, using the original eMMC with the RPMB partition intact and the eMMC is flashed with the original dump, Netflix and a few other Apps don't work. i assume all the DHCP keys and factory programmed RPMB access Key will be contained within the original dump, and as we are re-flashing the original eMMC i would expect every thing to work....
                                          12-10-2023, 10:43 AM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                          09-06-2024, 05:30 AM
                                          Sony VAIO SVE1413WPN Notebook E Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVE1413WPN Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVE1413WPN boardview and SVE1413WPN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony...
