Magnavox 42MF237S/37 weak picture
  • Toasty
    • Jul 2007
    • 4171
    Got this in a few months back and finally got around to working on it.
    Initial complaint is that it would not turn off. Found about half of the main PSU caps blown. Did a complete recap of board and reinstalled. Set powers on and off with no issues in that area.
    However, when initially starting the center of the screen looks like someone threw ink at it. The "ink blobs" slowly fade away in the course of about 2 minutes but the center of the picture vertically has a graininess to it and the overall picture is dim and weak.
    Looking for some guidance here as to what to check.
    Panel: Samsung 842AX
    T
    veritas odium parit
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Magnavox 42MF237S/37 weak picture
    I've had this same problem before same model. Couldn't cure it. The panels well used most likely.
    Check vs and VA on startup..Also check vscan.
    From the sounds of it it sounds like vscan may be low. Check this voltage against the panel label.
    • Toasty
      • Jul 2007
      • 4171
      Thanks for the input. I was thinking the panel was shot but needed some confirmation.
      Have a manual or link? Elektrotanya doesn't seem to have this one...
      T
      veritas odium parit
        Z-sus or X-main with "ink blobs" problem. not panel.
        • Toasty
          • Jul 2007
          • 4171
          Was hoping you'd chime in.
          What about the lightness/weakness of the display?
          What issues should I look for on those boards?
          Manual source?
          T
          veritas odium parit
            What's the panel in it? LG or Samsung? LG usually have ink blobs issue with Z fault (picture can either be OK or it can be dim) whereas Samsung is usually only dim.
            • freakaftr8
              • Oct 2012
              • 3743
              That model uses samsung.
              • Toasty
                • Jul 2007
                • 4171
                Post 1 - Panel: Samsung 842AX
                veritas odium parit
                  I'd check Ve and fuse on X-main then. Ink blobs rare with Samsung, but suppose it could happen.
                  • Toasty
                    • Jul 2007
                    • 4171
                    Still looking for a manual. Anyone?
                    T
                    veritas odium parit
                    • Tr0ll
                      by Tr0ll
                      Original T-con:
                      First replacement T-con:
                      10-07-2023, 07:48 PM
                    • JJAAMM
                      by JJAAMM
                      Problem
                      07-06-2023, 06:01 AM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • sudz28
                      Magnavox 27MS5402/17 CRT - no picture, flashing green light
                      by sudz28
                      I'm going to assume my beloved Magnavox CRT is toast, but also figured maybe this was a good opportunity to dip my toes into he circuitry waters and maybe learn something new. Also, I don't want to trash it if it's a fairly cheap/easy fix!
                      My 20-year-old Magnavox has gotten me and my kids through many a gaming console change and worked great up until the other day. Following a long distance move, it sat in our garage for a year and now that I brought it in and turned it on I get no picture; instead, a green light blinks on the front of it; 7 flashes, one long flash, then 3 more...
                      02-08-2022, 10:09 AM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
