LCD32762HDF lcd tv "crashing"
  • charlierfc
    • Mar 2013
    • 93
    • scotland
    hi all, ok i have the above tv. i had it for a while.
    The problem with this one is the tv powers on ok (after i replaced the psb) but now im having a fault where after the set is on for a min or so the tv crashes so the keys at the side can not be used, apart from the volume keys.
    if left on the tv gets worse till the backlight flickers off.
    the readings i get from psb look fine,maybe high esr?
    or am i looking at main board fault?
    any help please?
    regards charlie
  • Rictech
    Panasonic SA-MAX770PU SMPSU board fault....
    by Rictech
    Hello everyone. 😀
    As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
    Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
    Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
    This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
    There are no devices that have exploded or otherwise show signs...
    08-26-2024, 01:05 AM
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
    ESR meter came to the rescue again today with a PLC I/O card fault
    I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
    I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
    One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
    12-18-2023, 08:17 PM
  • Agent24
    What kind of fault causes this image error?
    by Agent24
    I took a look at a television for a friend, it has some serious image fault. I don't know what the cause is or if such a fault is even repairable.
    The T-con board seems to be integrated into the panel so looks even more annoying to work on than normal.
    What's the most likely cause of this problem, does anyone know?...
    09-22-2025, 11:42 PM
  • 6BW6
    Win7 Performance test stops
    by 6BW6
    I had a dodgy Molex Sata lead go bad that cause crashes once in a while, after repairing all is well with no crashing BUT.... Windows performance test stops. I get-:
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: WinSAT.exe
    Application Version: 6.1.7601.17514
    Application Timestamp: 4ce798fc
    Fault Module Name: atiuxp64.dll
    Fault Module Version: 8.14.1.6463
    Fault Module Timestamp: 56254af6
    Exception Code: c0000005
    Exception Offset: 000000000000dc14
    OS Version: 6.1.7601.2.1.0.256.48...
    05-29-2023, 04:21 PM
