Bush BPDP42HD3
    Re: Bush BPDP42HD3
    If at least they said "untested" but most in fact seem to claim the boards as fully tested.
    I buy from some other suppliers who actually say their parts are untested and offer free replacements (tell you to keep the bad board), they are at least honest!
    • flocko
      • Nov 2012
      • 1121
      • uk
      Re: Bush BPDP42HD3
      Can i ask you what there trade name is?
        Re: Bush BPDP42HD3
        Parts4u.me.uk is one of them, forget the name of some others.
        I am going to, at some point in the future, build a search engine for finding TV parts...
        • flocko
          • Nov 2012
          • 1121
          • uk
          Re: Bush BPDP42HD3
          Thanks for that Tom will give them a go
          • matyka
            • Jan 2015
            • 179
            • Uk
            Re: Bush BPDP42HD3
            Hello,I have the same bush tv ,but the fault is I have no picture but I have sound .Any idea where to start ?
            thx
            • flocko
              • Nov 2012
              • 1121
              • uk
              #26
              Re: Bush BPDP42HD3
              Just read back over this post and start to do the checks that I was told to do? if you need any more help after that we are here to help, and yes I still have all of the parts for these sets Flocko
              • matyka
                • Jan 2015
                • 179
                • Uk
                #27
                Re: Bush BPDP42HD3
                Hello,I have all good reading from the psu with y-sus and x-main disconnected
                Vs-207.6v
                Va-55.2v
                If I connect back both the psu starts cliking and the voltages drops .
                If I connect just the Y-sus with the ribbon from the T-con disconnected and the X-main disconnected I have constant reading from Vscan -193.6v and Ve-91.1v
                If I connect the ribbon from T-con to the Y-sus with the X-main disconnected the voltages drops.
                This mean the X-main is faulty or the T-con board ?
                  Re: Bush BPDP42HD3
                  You will need to replace at least X-main & Y-main, maybe even Y-buffer
                  • flocko
                    • Nov 2012
                    • 1121
                    • uk
                    #29
                    Re: Bush BPDP42HD3
                    As Tom points out all three board could be faulty? with this model it has been found that a bad X will damage a Y , a bad Y will damage an X and bad buffer will take X and Y. So you now need to check each one for shorts, and when you replace them check replacements for short as well, as a lot of the boards come from damaged screen sets, not testing can lead to damage to you once good boards. the best way is to replace all three with known good working boards. also check old posts for PS42Cxxx models as these use the same boards Flocko
                    • matyka
                      • Jan 2015
                      • 179
                      • Uk
                      #30
                      Re: Bush BPDP42HD3
                      From the picture wich pin to use to check the buffer board please.
                      1.GND
                      2.GND
                      3.Reset
                      4. 5v OUTL
                      5. GND
                      6. GND
                      7. LE-2
                      8. OC2-A-2
                      9. OC2-B-2
                      10. OC1-2
                      11. CLK-2
                      12. GND
                      I think one is any GND ???
                      • flocko
                        • Nov 2012
                        • 1121
                        • uk
                        #31
                        Re: Bush BPDP42HD3
                        Check out You Tube Tom has a how to test plasma Y buffers, that will show you what you need to know, have you found anything on the X or Y ?
                        • matyka
                          • Jan 2015
                          • 179
                          • Uk
                          #32
                          Re: Bush BPDP42HD3
                          I found x-main shorted at Q4007 and Q4001 both have RJH30E2 on them ,I ordered 2 pcs from ebay for £2.75
                          I checked the Buffer board and I have found shorted IC .
                          GND used pin 1 and found on the second connector from the top off the Buffer board and I think IC number 3 is shorted to GND because a couple of pins have continuous connectivity.
                          • flocko
                            • Nov 2012
                            • 1121
                            • uk
                            #33
                            Re: Bush BPDP42HD3
                            That's a good price I don't pay a lot less from China (40p each), but then again X board only £10. So will you be replacing buffer IC or getting another board? whatever way you go make sure that it is clear of shorts before you power the set up, as any shorts will take you back to were you started, and we have seen this over and over again.
                            • matyka
                              • Jan 2015
                              • 179
                              • Uk
                              #34
                              Re: Bush BPDP42HD3
                              I changed the 2 shorted RJH30E2 on X-main ,I got another Y-main but mine was fine as-well.
                              I order another buffer board from ebay -£15 with different PCB NO but working with bush and samsung . PCB no :LJ41-08594A
                              Checked and was ok-no shorts on.
                              Before to connect the buffer board I checked all board and had good readings .
                              Connected the buffer and TV WORKING for the last days on.
                              Thank you flocko ,TOM66
                              • flocko
                                • Nov 2012
                                • 1121
                                • uk
                                #35
                                Re: Bush BPDP42HD3
                                Happy to help and nice to know its working Flocko
                                • matyka
                                  • Jan 2015
                                  • 179
                                  • Uk
                                  #36
                                  Re: Bush BPDP42HD3
                                  Hello again, I had the tv for some time and now I have another problem with the sound
                                  I have no sound, tv working fine with no sound
                                  Any idea where to start?
                                  Thx
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #37
                                    Re: Bush BPDP42HD3
                                    Thx
                                    Image of the mainboard ?
                                    • matyka
                                      • Jan 2015
                                      • 179
                                      • Uk
                                      #38
                                      Re: Bush BPDP42HD3
                                      Hello yes I upload one now
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        #39
                                        Re: Bush BPDP42HD3
                                        Ok, do you get sound out of the ear phone jack ?
                                        • dick_barton
                                          • Aug 2015
                                          • 6643
                                          • Wales
                                          #40
                                          Re: Bush BPDP42HD3
                                          What is the IC number?
                                          • FlailingEngineer
                                            Help with Bush Tv (Vestel 17mb95m Mainboard)
                                            by FlailingEngineer
                                            Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                            Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                            05-31-2023, 06:52 AM
                                          • tyler123456
                                            Need help identifying an IC chip on a Bush DAB radio (BD-1801)
                                            by tyler123456
                                            Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
                                            I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
                                            I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
                                            Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
                                            Anyone...
                                            08-16-2024, 12:51 PM
                                          • Johnny.p
                                            Bush WI-1810 Internet Radio
                                            by Johnny.p
                                            I recently bought an internet radio Bush WI-1810, it came with a power supply that when plugged in promptly damaged the radio. I discovered too late that the radio was 6v and the supplied adaptor was 12v. The radio still powers on but the wifi is not working. I have attached a few pictures- Image 2 showing the board with damaged component top right labelled U8. There are several other similar components like U9 (image 3) that I'm wondering could be a replacement.
                                            U9 has a code on it S5EJI- I have searched several smd code sites and the nearest I can find is for a mark of S5E -listing shows...
                                            11-25-2023, 04:18 AM
                                          • razzer05
                                            Bush LE50GY15M - Firmware needed, Please!
                                            by razzer05
                                            I did a silly thing and tried to update the tv (Bush LE50GY15M) with a "allupgrade_6308rtbm.bin" off the internet with the same board name "T.MS6308.U701" and it now no longer works.
                                            I have researched quite a bit since Fridays messup, I've gathered a bit of information and tried multiple "allupgrade_6308rtbm.bin" files off the internet to try and fix it.
                                            The information I've come up with:
                                            A possible clone of "SEIKI SE50UO01UK" with a Bush Logo
                                            The board is as mentioned: "T.MS6308.U701"...
                                            09-23-2020, 03:43 PM
                                          • stav242
                                            BUSH DLED43IHDHDRS 17MB130S Firmware needed
                                            by stav242
                                            i have a BUSH DLED43IHDHDRS.
                                            the MB - 17MB130S is not booting - it did once then wont boot again.
                                            Suspect its the corrupt firmware issue.
                                            Where can i find the correct firmware for this model ?
                                            11-02-2022, 03:39 AM
