Philips 37PF7321D/37 going to MENU by itself
  • 120volts
    • Oct 2013
    • 57
    This Philips kept going into the MENU all by itself.
    Sometimes within minuets, sometimes not for twenty minuets.
    Philips had this problem about six years ago at the time this one was made.
    The Philips web support page states that the problem can be fixed by installing the latest firmware.
    After I installed the firmware the TV still had the same broblem.
    I then unplugged the Control/button panel from the main circuit board and the problem went away.
    I ohm ed out the Control/button panel and found it to have leaky micro switches. After replacing them the TV works Great.
    Dan "TV Tinkerer"
  • R_J
    • Jun 2012
    • 9624
    Re: Philips 37PF7321D/37 going to MENU by itself
    This problem is common to other makes as well, changing channels, turning on/off by itself, etc.
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • Ierwin
      Philips 58PUS7805 Menu working but no/weird picture from video sources
      by Ierwin
      I got a 58pus7805 that shows some weird behavior.
      The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
      However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
      I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
      I managed to install the latest official firmware by holding the control button while plugging...
      03-10-2024, 12:50 PM
    • Sharpa
      Repair attempt Philips 55OLED804/12
      by Sharpa
      I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
      The symptoms when bought: Philips logo appears then tv turns off
      Things tried so far:
      1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
      2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
      Yesterday, 08:30 AM
    • Robby-Gr
      TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
      by Robby-Gr
      I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
      However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
      The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
      Additional issues:...
      09-27-2025, 12:02 AM
    • alro7779
      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
      by alro7779
      Hello, guys!
      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
      09-14-2025, 12:25 AM
