Samsung Plasma hpr4272
  • Tekno
    • Oct 2013
    • 18
    Hello guys I am pretty new to repair TV..i have background in computer repair well i got This samsung plasma turns on blank screen...it makes the startup sound but no display...I have checked power supply board seems to be outputting all voltages to all boards and no visible blown caps...how can i confirm Y or Z board is issue...i dont hear any sound but the start up tv sound
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Samsung Plasma hpr4272
    The contol-board has some jumpers on. You cab bridge three and four as I recall, which will give a variety of test-patterns cycling at 10 second intervals....
    A pic of the individual boards and the rear complete of the set would be a good start....
    TELEFIX
    • Tekno
      • Oct 2013
      • 18
      will post the pics up tomorrow. thanks for the reply
      • Tekno
        • Oct 2013
        • 18
        ok so here are some pictures...
        • Tekno
          • Oct 2013
          • 18
          there seems to be a crystal on logic board that has a dent in it…in laptops a faulty crystal causes no display..not sure if this the case with PLASMA tv….i read somewhere to check Y OR Z BOARD for no display issues after powerboard has been cleared..powerboard seems to check out…dont know how to go about troubleshooting the rest of the boards..any help would be greatly appreciated.
          • Tekno
            • Oct 2013
            • 18
            only board i forgot to take a pic of is the control board which is under the logic board…would faulty control board cause no display? …tv powers on makes powering on chime..but displays no picture screen stays blank
            • Tekno
              • Oct 2013
              • 18
              Common components to check on y sustain ? I suspect it the y sustain board but dont know how to verify
              • Glitcher
                • Mar 2013
                • 673
                • USa
                Have you checked the white ceramic fuse to the right of the larger heatsink? If its good than the main IPM circuit under it should still be working. If so move on to the next step.
                Check the MOSFETs under the circled heatsinks, you may find than one or more of them has gone bad. You will have to desolder the heatsinks to get to them. They are in parallel so you will have to lift the legs of each one to test if they are shorted.
                (Not as common) But there may also be some shorted diodes, you can test them in circuit if they are shorted or not.
                  09-07-2024, 05:50 AM
                • willis6732
                  Samsung Plasma PN43E450A1F - No Picture / Pop Sound
                  by willis6732
                  The customer of this TV Heard a pop sound before it went dead.
                  The VS and VA voltages turn on imediatly and then slowly die off.
                  I got a replacement Y-Board (Large board on the left) from aliexpress and still no luck
                  If tested all the IC chipson the board all the way on the left by running meter along the connectors and couldnt find any shorts there...
                  I think ive checked most the capacitors for shorts as well as most of the diodes and mosfet/transistors on the big boards.
                  https://photos.app.goo.gl/KDyLcgB38Bh699Zr6
                  09-26-2023, 06:02 PM
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • jchang
                  Samsung UN70NU6900F no picture and no sound
                  by jchang
                  Hi all
                  I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                  Symptom:
                  No picture no sound.
                  When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                  No sound at all.
                  What I tried:
                  1. I tried unplugging the left or right ribbon...
                  01-09-2023, 06:28 PM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
