Anyone tried improving the reliability of Cruddy Samsung Plasmas?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    We all know how cheap and cruddy these things are--But Has anyone tried doing some proper upgrading throughout the entire set to improve reliability?
    I have one of these things, and picture wise--it aint bad. Its a PS-42C450, not the most reliable beast in the world from the number Ive seen and heard about!
    My plans for upgrades are as follows.
    Replace the BN44-00329B PSU with one from a 50" set,--The BN44-00330B.
    --Its pin for pin/plug-n-play compatible. The 50" PSU has a larger Transformer, and better heatsinks fitted so will be less stressed in comparison to the 40" original--which runs--Pretty Darned Hot!
    Before fitting however--That one needs some work. Replace all those nasty cheap caps with Rubycon/Chemicon/Nichicon, of the correct series for their jobs.
    Re-work the standby supply regulator to remove the issue whereby the 30V rail derived from the switching transformer by two 15V zeners--In Series, the regulator chip runs from--kills the 32V rated chip!
    --Seen a few of these--so something is obviously causing this problem, giving a symptom of completely dead--no life at all-set.
    Sanken the maker of the chip specify 'Absolute Maximum VCC of 32V' guessing so as not to stress out the internal 5V reg the chip has. The chip's minimum running voltage is 8.5V
    The Max power-output this chip can supply (assuming the transformer was rated for that amount) is 90W. Its actually supplying only 40 odd watts when the set is on, and just a couple in stby. Stress due to output power overload isn't the cause of the problem.
    --Similar PSU's like say--the '329 using a similar chip with similar ratings from same maker, run it from 18V using a single zener diode as its reference.
    Oh--and replace the original STR-W6053S switching-regulator chip for a new unstressed one.
    Up-value some specific caps, particularly those of the Vs, Va, 5V and 15V rails, add some Os-Cons to the 5V and 15V rails.
    The Vs decoupling cap of the '330B PSU is larger anyway at 220uF instead of the 150uF of the '329B, prolly go up to 330uF for that one.
    Replace all the nasty leccy-lytics of Y-Main and X-Main, and uprate the 150uF 200V Vs de-coupling to 200uF 220V Rubycon BXC-P caps.
    (You can almost hear the bean-counters saying--Capacitance costs money boys--Cut it down to bare minimum! hence my increasing of some in the set.)
    Increase cooling of the Y-Main and X-Main by adding heatsinks to the existing and a small fan to assist in cooling.
    Add a case fan to the set to extract air from the top--as certain Panasonic sets do. I have some excellent virtually silent fans culled from a wine-chiller that will come in handy for this....
    Increase the size of the heatsink fitted to the main-board's processor, that is known to cause problems due to temperature issues.
    Anything else you guys think would be a good idea?
    I have now Three complete sets of working boards for this set, (and 4 PSU's) so all would not be lost if it went titties upwards!
    --I can re-work the PSU and fully bench-test it under lamp-loads at full power, set the rails up etc run it for some hours before fitting to the set, --one board then I know will be fine!
    TELEFIX
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Anyone tried improving the reliability of Cruddy Samsung Plasmas?
    Wot....?
    No Comments at all!--Would have at least expected the ' Its old--Why bother,--sell the thing and buy a Panasonic!'
    TELEFIX
    • SeanB
      • Jun 2013
      • 41
      • South Africa
      All that would improve reliability, but you know the bean counters did the original to cut costs anyway. If the original is a cheap or free one then go for it.
      • R_J
        • 9588
        Everybody wants cheap tv's. So they use cheaper components etc. to bring down the price and now they complain that they don't last. Bring back the $10,000.00 42" plasma built to last. who wants a $500.00 50" anyway.
        The new tv's keep me in business. sort of
          Panasonic had good quality 42" FHD plasmas for £350 at one point. Nicely made 2010 series. Only minor issues.
          But Samsung undercut them, and Panasonc cheapened up to match... now they've quit plasma.
          • Perry Babin
            How do organic polymer caps compare to liquid electrolytic for reliability
            by Perry Babin
            I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
            If not organic polymer, what would be the caps that could take the most abuse?
            08-18-2025, 04:04 PM
          • nobbnobb1
            TVs vs Computer Monitor Reliability & Failure Rate
            by nobbnobb1
            Anecdotally, it seems to me that TVs fail much more often than computer monitors judging from personal experience and looking at the classified where people are getting rid of broken/malfunctioning TVs all the time.
            So I'm just wondering if this is the case? Is there something inherent in the design of monitors that makes them more reliable? I would've thought they'd be operating under more severe conditions than a TV. For a typical family, a TV may only be on for a few hours every day. Whereas a monitor could be on 8+ hours, along with countless power cycles turning on/off as power...
            07-07-2024, 10:57 AM
          • 13mh13
            Aluminum SMD caps vs thru hole caps (reliability)
            by 13mh13
            The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
            https://i.postimg.cc/kGrR6BpZ/image.jpg
            I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
            I have not tested/replaced those alum. SMD electro PCB caps.
            Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
            All the thru hole electros I removed / replaced on this CDP (and most...
            04-05-2024, 07:41 PM
            RCA WHP141 wireless headphones wired up
            by momaka
            OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
            Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
            As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
            02-22-2023, 06:28 PM
          • Sibiemofokeng
            Samsung plasmas power supply
            by Sibiemofokeng
            can anyone advise me about most of samsung power supplies,most of them when you put the main supply and switch on the tv ,voltage drops from high to zero ,like when i test Vs voltage maybe Vs is 208 ,then it drops from 208 to zero .i make this disconnecting Z andY board for a power supply test.is it a faulty logic board or the main board itself?i really have no understanding about this issue.
            09-12-2021, 12:08 PM
