Samsung plasmas power supply
  • Sibiemofokeng
    • Mar 2020
    • 5
    • South africa
    can anyone advise me about most of samsung power supplies,most of them when you put the main supply and switch on the tv ,voltage drops from high to zero ,like when i test Vs voltage maybe Vs is 208 ,then it drops from 208 to zero .i make this disconnecting Z andY board for a power supply test.is it a faulty logic board or the main board itself?i really have no understanding about this issue.
    • 21597
    Re: Samsung plasmas power supply
    no model number......
      03-31-2024, 02:12 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      07-01-2024, 06:34 AM
    • cheeky2
      Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
      by cheeky2
      This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
      I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
      Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
      06-15-2025, 05:12 AM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
