BN44-00472A power off loop
  • case sensitive
    • Jul 2014
    • 13
    Hi I have a Samsung BN44-00472A from a UE32D4003BW.
    The TV didn't power on and I found that ICM801S (STR-W6053S) was shorted and the fuse FM801S had blown so I replaced both of those.
    The board now powers on for around 1 second then there is a click and it powers off, this repeats until AC power is removed.
    I've checked the main rails on the cold side and resistances to ground look sensible:
    B13v / Vamp: 23K
    B5v: 216 ohms (schematic shows a 220 ohm resistor connected between it and ground)
    A5v: 1.5M and falls slowly
    Vdrv: 6M and falls slowly
    PS-ON: 65k
    PWM_DIM / EPWM: 6.5K
    BLU_ON: 6K
    13v1: 880K
    DRV_OCP1: 67K
    DRV_OCP2: OL
    PWM_W1: 7.5K
    I'll power it on later and double check voltages but from what I remember they all seemed OK for the short time they are up.
    I think DRV_OCP1 was around 2.5v (comes from SEM5025 fail pin) so I assume the problem is something to do with that.
    Schematic attached, will upload board photo when home later.
    Any ideas what might cause this?
  • Chungalin
    • Jul 2014
    • 429
    • Spain
    • Films, film music, computers
    I’m stuck in the same place. In my case, it’s a very similar BN44-00471A from a UE26D4003BW (I’m actually using schematic for BN44-00472A and I’ve found minimal differences). All voltages fall every second. I disconnected all supply to the backlight driver and then it turns on without problem (A5V, B5V, B13V OK). But as soon as I power the backlight and I connect DRV_OCP1 (without LED strips connected), the problem comes again. It seems that IC SEM5025 rises FAIL pin to 5V every two seconds, and I still haven’t found anything bad or shorted. Checked all MLCC around it.
    • Chungalin
      • Jul 2014
      • 429
      • Spain
      I’ve eventually repaired it, although not on my own merits. DRV_OCP1 wasn’t a problem after connecting the LED strips. If you disconnect Main board, the PSU turns on by default and the backlight works at max brightness. The problem arised from DRV_OCP2 after connecting MAIN board. I found a blog (Kent Liew LCD repair) that explained a very similar case with BN44-00472A. He found that the culprit is QQ9101 (MMBTA92, marking 2D or YV, depending on manufacturer), that is responsible of raising DRV_OCP2 protection. My transistor tested normal, but I tried to replace it anyway. Now it works!
      • Andreasbest
        HP LA-H32AP motherboard power on for 5 secs
        by Andreasbest
        Hello.
        Received a LA-H32AP motherboard with AMD cpu, only reaction is the power led (LED1) that lights up for 5 secs, nothing else.
        Summary↓
        The laptop was working normally the previous day.
        When pressing the power button, LED1 (Power LED) turns on for a few seconds and then turns off. The motherboard does not boot.
        Some power rails remain active for several seconds after LED1 turns off.
        Troubleshooting already performed:
        • Tested different RAM modules.
        • Tested without RAM.
        • Tested again with RAM installed — exactly the same behavior.
        • Removed
        10-19-2026, 03:11 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • to5it0
        Title: HP EliteBook 840 G3 – Auto Power On Loop, Caps Lock LED Stays On – Need Power Rail Values Near CPU
        by to5it0
        Laptop: HP EliteBook 840 G3
        I’m troubleshooting a motherboard from an HP EliteBook 840 G3 and I’m facing a strange power issue. Problem Description
        • When I plug in the charger, the laptop automatically powers on (without pressing the power button).
        • The Caps Lock LED stays ON continuously.
        • The Power LED, Wi-Fi LED, and Mute LED also turn on.
        • After a few seconds, the laptop turns off, then automatically powers on again, creating a continuous power loop.
        Measurements
        I checked resistance to ground on the three inductors (coils) near...
        03-08-2026, 03:32 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
