Hisense 55Q9G Android reset / factory firmware reload
  • mon2
    • Dec 2019
    • 14512
    Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
    After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again. At this point, the remote can be used to power up again -> Android splash screen launches and the cycle repeates.
    No red blinking lights so suspecting this to be a s/w fault rather than a hardware one.
    Is it possible to reload the latest firmware / Android OS for a fresh start? At this time, believe it is an Android OS corruption.
    There is a 'service' hole on the back left of the TV and what appears to be a dome switch at the end. Is this a factory RESET button? The tactile dome switch does not appear to be compress when poking the hole so may have to remove the back cover to review this switch.
    Welcome all suggestions. Thanks.
  • wamo
    • Apr 2018
    • 27
    • MX
    Hello, the Hisense TVs have a reset button for the system. Disconnect it from the power outlet, press the button, and while keeping it pressed, reconnect it to the power outlet. If it starts up on its own, that resets the system.
    However, I have been experiencing several issues with them, and the most common problem is that the EMMC memory gets damaged and needs to be replaced... which is a problem because the systems are not easy to find πŸ˜₯πŸ˜“
    • mon2
      • Dec 2019
      • 14512
      Thanks. Which button ? Is it the SERVICE button or the power button? We have a SMD work station so that is a good start. Are schematics available for this unit? Which EMMC needs to be replaced? You are sourcing from a donor board? Perhaps can find a replacement board from Aliexpress?
      • mon2
        • Dec 2019
        • 14512
        Update - Hisense just replied and also agreed that the fault may be a corrupt Android OS. For which they have supplied the URL to allow us to download the latest firmware using a USB stick for this unit. However, the serial # on the unit (purchased from Costco) does not work and reports an incorrect serial #. This is ghetto.
        Any chance we can download the firmware from here or another URL for the 55Q9G ? Found 393 pages of talk on the AVS forum but so far, no direct firmware link for this model.
        2020 Hisense H9G / Q9G series 55" & 65" Owners Thread (No Price Talk) | Page 3 | AVS Forum
        URL page for the firmware download:
        Landing (hisensefirmware.ca)​
        Serial # 55G2023FDH00195
        • lotas
          • Jan 2016
          • 4708
          • Russia
          Here is a link to the firmware, only "65" diagonal. https://www.avsforum.com/threads/202...#post-62359953
          • mon2
            • Dec 2019
            • 14512
            Thanks. This TV is a 55". Any chance you would have a compatible firmware for that sized unit?
            Hisense replied with the following:
            Thank you for contacting Hisense Customer Support.
            We have received your information however based on the message received , it means we currently do not have firmware available for this model as not all models will have updates either due to being an older model TV or the firmware is not uploaded.
            Being Android, there must be a reload process to reload the firmware over USB.
            • lotas
              • Jan 2016
              • 4708
              • Russia
              Yes, I see that you have a 55 diagonal, if this firmware (update) completely rewrites the eMMC, then there may be a problem with the image, if it does not affect the panel settings, then everything will be fine. I also found the serial number and it also blocks it.
              The problem may be that the serial number does not match your region, your country in which you are registering it.
              • wamo
                • Apr 2018
                • 27
                • MX
                I have saved this page, https://support.halabtech.com/index....file&id=710442 on some occasion it has allowed me to download some firmwares from there....
                • mon2
                  • Dec 2019
                  • 14512
                  Thanks again. Phoned Hisense Canada (who is very responsive) and they stated that they only store 2 years of firmware images on their servers. That is why the serial # is being rejected. Kind of lame but the support staff was very fast to pick up the phone.
                  How to test the image you have posted? Extract onto the root of a USB media and power up? Will attempt it.
                • mon2
                  • Dec 2019
                  • 14512
                  Thanks. The USB media was detected on my FAT32 formatted 8GB stick -> the 65" firmware was rejected with an 'ERROR' in red text. Then the Android OS continued to boot like before and power cycles after shortly after reaching the APP screen.
                  Could this be a power supply fault? I do not believe so but wanted to ask if this is a common issue on this brand. After the power is shut off from this 'crash' - the white LED is dark for at least 20-30 seconds. Then the WHITE LED is on and we can repeat this cycle with a remote or button at the bottom of the TV.
                  Next, can remove the cover to check for potentially bad caps on the power supply. Aliexpress offers a few nice tools to allow for testing of the power supplies using a universal load. Also they have a replacement universal power supply based on a 24V 5A power adapter that creates the assorted power rails to potentially power this unit. This is to allow ruling out the power supply as the guilty party.
                  • wamo
                    wamo commented
                    Editing a comment
                    "You don't have a smaller memory, like 2GB? It could be because of that... I don't know why, but it doesn't work with larger memories."
                • Diah
                  • Feb 2013
                  • 6421
                  NO, its firmware
                  • lotas
                    • Jan 2016
                    • 4708
                    • Russia
                    Here's another link to 55.
                    https://www.reddit.com/r/Hisense/com...mment/jk801rr/
                    https://hisense365americas.sharepoin...o.com&e=bZ23UT
                    • Diah
                      • Feb 2013
                      • 6421
                      free of charge advice .. don't use web to search firmware for android... call them call and tell yours Serial don't come via yours dummy web....id they have will send u direct link
                      i check too on Hisense server cannot find yours set
                      web : http://hisenseczech.myqnapcloud.com:...?ssid=0MmKZDg#
                      password: Hisense1234
                      • mon2
                        • Dec 2019
                        • 14512
                        Thank you guys. Attempted again as per Reddit articles (by Hisense) to use < 16GB (mine is 8GB) USB 2.0 stick with the above 65" firmware (ONLY - no other files onboard this stick) and was previously formatted with FAT32. The USB media is found and the OS is 'Checking the pkg file' for about 5 mins or so and then powers off but the white LED remained lit. That is, the fact that the 'checking' process ran for 5+ mins, this confirms the power supply is NOT the fault. However, the file was apparently rejected since I am still on the same OS quirk with the same apps as per the start.
                        • mon2
                          • Dec 2019
                          • 14512
                          Hi. A few updates and questions on this case.
                          1) Proceeded to order a factory new controller board for this 55Q9G to service the worn out emmc which prevents the Android OS from properly booting. Always crashes at a fixed point of the boot process. The vendor shipped a controller board for the 65" Hisense as the 55" main board is not available and is EOL. This was an honest mistake by the vendor as we also had a 65" request with a backlight fault which is not worth repairing.
                          2) Applied the new board on arrival and now facing a led flicker on first power on and then this fault disappears. The vendor noted this could be due to the difference in the number of LED zones on the 65" (188?) vs. 55" (132?). Any feedback?
                          3) The vendor noted it is not possible to reflash the firmware to change the models yet the controller board is 100% identical - that is the firmware is obviously different inside the controller boards. A vendor in China noted the fault is not the controller board but the power supply or led drivers. Could the LED driver be at fault? We still have the original non-working controller board for testing if required. The unit is with the owner.
                          Summary: The 65" main board works 98% on the 55" 55Q9G for which the main board is no longer available except for the initial power up led flicker. How to eliminate the led flicker? Replace with a constant current universal LED driver? The flat FPC cables are not fun to interface with so prefer not to take this route. Will double check the connector seatings but we were extremely careful to not flex any of the rigid fpc cables, etc. The new board did perform 2 automatic firmware updates from the Hisense server.
                          Welcome all feedback.
                          Shipped board that was installed:
                          T270342
                          65Q9G T270342 Main board
                          Board that should have been shipped and installed but is EOL and no longer shipping:
                          55Q9G T270089 Main board Main Board ----NO STOCK EOL
                          Click image for larger version  Name:	new1.png Views:	0 Size:	821.5 KB ID:	3179072
                          Click image for larger version  Name:	new2.png Views:	0 Size:	1.94 MB ID:	3179073
                          • Diah
                            • Feb 2013
                            • 6421
                            that's True,,, since android Firmware share same package to all sizes.change the spec of the set in service menu enough to let the FW handle other Size BL Zone as they are all saved in FW..
                            • mon2
                              • Dec 2019
                              • 14512
                              Thank you. Could you please share how to perform this change in the service menu?
                              • Diah
                                • Feb 2013
                                • 6421
                                go to menu ... audio... advanced setting then go to balance keep ot high light and be sure its on 0... try press 1969 or 0532 the reset will be easy to you..you will have M letter on the top left ... press setting on RC it will open for you... any after change need to have clear chip in SM so all setting will pass together
                                • mon2
                                  • Dec 2019
                                  • 14512
                                  So using this process, we can change the screen size to 55" to fix this BL issue? This is awesome. Will share with the client so wish to be clear on the procedure. Thanks so much.
                                  • Diah
                                    • Feb 2013
                                    • 6421
                                    you will have option too for BL.... just be xcarfull dont miss with KEYS.... NETFLIX etc.
                                    • masterm
                                      JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
                                      by masterm
                                      TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
                                      Problem with TV:
                                      - Netflix stopped working so i tried to do factory reset from the TV menu.
                                      - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
                                      - After waiting for some time, the TV went into a boot loop.
                                      - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
                                      04-30-2024, 03:03 AM
                                    • neilc6
                                      Factory Reset Westinghouse WG55UR4100 Android TV
                                      by neilc6
                                      I repaired the backlights on this model (symptom flash of backlights, repaired seven bad, part#3P55TA004-A2 new strips available at Shopjimmy) and now the TV is stuck on the home screen. I can only turn the TV on with the remote and no buttons work once booted on the home screen. Only the TV buttons volume -/+ and on/off work. There is no physical menu or input buttons.
                                      I think a factory reset will clear it but not a lot of options. Tried the Sony Android methods of holding down the on/off button while plugging it it and holding down vol- with power on/off....
                                      05-26-2021, 03:26 PM
                                    • pfrcom
                                      Reset/erase Hynix SC210 to factory default
                                      by pfrcom
                                      Some Googling made this seem straightforward, but it ain't necessarily so:
                                      First try was Hynix Drive Manager, supposed to be able to do PSID reset
                                      In Win7 x86 context, what shoddy software – this greeted me first time I clicked it from Start menu:
                                      After wild goose chase triggered by the OpenGL bit, I tried swapping graphics cards until penny dropped when it still objected to a Radeon HD3450
                                      How I got it work:
                                      1. Command prompt
                                      2. Change to install directory \Program Files\SK Hynix Drive Manager
                                      3....
                                      04-23-2022, 07:30 AM
                                    • AJ847.63e
                                      A1708 unable to reinstall Monterey after factory reset - disk utility error 478
                                      by AJ847.63e
                                      I've got a A1708 which we decided to sell off as we no longer use it. We factory reset the device to wipe all data which went fine but when trying to reinstall macOS it fails with the generic β€œ MacOS β€œInstallation Failed, An Error Occurred While Installing”. I've tried the usual solutions like the first aid utility apple recommends and also disc utility delete the partitions but still get the same error. Digging into the logs you can see it's giving an error 478 but unfortunately wasn't able to get much info on that on google so I'm unsure where to go from here....
                                      02-20-2023, 02:51 AM
                                    • jougounou
                                      Ricoh spc830dn factory reset
                                      by jougounou
                                      Hello everybody
                                      just wanna know how to factory reset my ricoh spc830dn printer
                                      01-03-2023, 02:07 PM
