Neon C3770F 37" LCD TV - stuck in standby
  • Faz
    • Jan 2014
    This is my first post so please let me know if I have done something daft.
    I have been given a Neon C3770F 37" LCD TV with no remote control that appears to be stuck on standby.
    At first I suspected faulty capacitors on the power supply so I tested all the voltages as per the values written on the PCB and they all appear correct, I have also checked all the capacitors on the power board (MLT198TL v1.4) using an ESR meter, all appear fine.
    The side button for power is making contact, I tested this using a continuity check.
    I then turned to Google and found a couple of forum posts pointing towards a possible corrupted EEPROM issue. I tried a pin 5/6 short for 2 seconds, nothing.
    The main board is a CV109H V2.1, I believe it's U6 on the board. I have a Willem programmer and possibly an SOIC 8 adaptor somewhere.
    My next step was going to be to carefully remove the EEPROM, see if it will unlock and allow me to erase it, I've found some blanks on eBay for around £5 if mine is faulty otherwise I can hopefully reuse the original.
    What I have not managed to find yet is a dump file of the CV109H V2.1 EEPROM. I have found some pre-programmed ones for around £18 posted.
    Does anyone have a dump file of the CV109H V2.1 EEPROM I could possibly use please?.
    I'm not used to working on TVs, this is only my second one so if my diagnosis process is incorrect feel free to point in the right direction.
    Many thanks in advance for your assistance.
    Faz
  • flocko
    • Nov 2012
    • 1121
    • uk
    Re: Neon C3770F 37" LCD TV - stuck in standby
    The shorting out of the EEPROM does not work on this model , but you are right about it being U6 on the V2.1 board. Andy at OHM Supplies is your man for a pre-prgrammed one and he sold one to me last year at under £10 with postage he Was a member on here but i have not seen any posts from him lately, there is a long post on here about the 32" Neon with this same fault, hope this helps Flocko
    • Faz
      • Jan 2014
      Thanks for info Flocko, good to know that pin 5/6 sc doesn't work, £10 for a pre-programmed one seems reasonable, I looked on the Ohm Supplies website and it was £17.52 inc postage.
      I quite fancy having a go at extracting the existing EEPROM and re-writing it if I can manage to find a dump.
      • flocko
        • Nov 2012
        • 1121
        • uk
        forgot i have trade account with them. you could send Andy a message his user name on here is Ohm supplies, i dont hold out much hope for you finding a dump file Flocko
        • lepak06
          TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
          by lepak06
          Hello
          I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
          The TV is faulty with stuck in Standby RED LED. Can't power the TV.
          Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
          All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
          But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
          01-12-2023, 01:43 AM
        • toty79
          Hisense LTDN50K220WSEU stuck in standby
          by toty79
          Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
          As per Hisense tv title LTDN50K220WSEU stuck in standby
          PSU rsag.820.5687 HLL 4855WF
          Main rsag 7.820.5842
          I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
          05-01-2022, 04:39 PM
        • lego1234567
          LG 32LB1R - stuck in standby mode
          by lego1234567
          Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
          What could be the problem ? Thanks...
          01-21-2024, 03:39 AM
        • Stunt
          Hp Laptop Stuck on Hp protected by hp sure start screen
          by Stunt
          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
          screen that's it and stuck there. I left it until the following day and i still...
          09-02-2025, 01:51 PM
        • SidneyCanadas
          93C46 and 93C56 EEPROM
          by SidneyCanadas
          I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
          https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
          Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
          06-14-2023, 01:16 PM
