Building a Univeral P.S to Test LCD TV
  • Ltank
    • Jun 2013
    • 776
    Many times we have TVs that the Power Supply is bad but the rest of the boards status are unknown.(lighting strike) Generally you repair/replace the Power Supply then you can test the Main Board etc..You tell the customer the P.S. is bad and you tell them a certain Price but after you buy the SMPS you find out that the Main Board is bad. To avoid this a universal PS is needed to test the remaining boards.
    Making a Univeral Power with 24 vdc for invertors, 12vdc for audio, 5vdc for standby. A high wattage Computer P.S. can be made to fullfil most needs.
    Wire jumpers from the Molex to the Main Board etc can be set as needed when needed. Sure its a Pain but at least mostboards can be tested. A bright
    LED flashlight can be used to view image on screen if your unable to fire up the inverters.
    What wattages / amperage would you guys recomend for each of the desired voltages? Pointers Anyone? Bad Idea?
  • Asraf Atb
    by Asraf Atb
    01-27-2025, 05:02 PM
  • cekcons
    g1 assassin Rev 1 bios dump - main and backup needed
    by cekcons
    main and backup ic dead so i cant post corrupt bios cause its 01 all over.
    thanks
    01-23-2024, 03:26 AM
  • questore
    Lenovo NM-D562 v2.0 main EC programming help needed
    by questore
    Hello Everyone,
    I have this board that has an autostart as soon as i connect the charger (no POST) and restarts after 20 seconds. cannot be turned off.
    I'm suspecting main EC firmware problem (IT8227E-192)
    Since this board has only EC_KSI6 and EC_KSI7 pin on keyboard connector to the EC this cannot be programmed trought it.
    I would like to know if anyone can give me instruction how to program the EC.
    In the Vertyanov tutorial instructions I have seen that alternative is using 8pin direct cable soldered to board.
    Anyone knows hows if that is working...
    07-09-2025, 01:52 AM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
