Phillips 47PFL5704D/F7 Dead
  • Ltank
    • Jun 2013
    • 776
    I got this TV in today. It was dead the 6.3 amp 250v fuse was blown. Tried another fuse and that blew. I checked the Bridge Rectifier tested good out of circuit and reinstalled it. Found D101 and D102 1N4007 diodes shorted. I replaced them, installed correctley but the fuse did not blow but it smoked IC101 drain pin on the resonate IC and opened the trace from that pin to the transformer and overheated several ceramic caps between the hot and cold side of the power supply. I did not have a chance to check output at main filter cap due to the IC burning etc.. Never seen this before.
    Does anyone have a schematic for a 272217100692 Powersupply inverter board? I could not get a Service manuual for this TV or a schematic for the power supply. I will post pics tomorrow when back at the shop.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Phillips 47PFL5704D/F7 Dead
    Did you ever get back to this?
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      Try replacing u101 and r5. Mine kept blowing the fuse and smoking the r5 resistor. It worked for me.
      • Ltank
        • Jun 2013
        • 776
        I ended up replacing P.S.
        • dellxps15
          macbook a1707 15 inch trackpad dead. blown fuse identification
          by dellxps15
          hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
          another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
          04-30-2024, 10:48 AM
        • AccountSaver
          Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
          by AccountSaver
          Here is a pretty crazy one.
          Step 1.
          Laptop was brought to me as dead not working. Removed everything , cleared everything.
          Step 2.
          Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
          Step 3.
          Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
          Step 4.
          Lets ,dive into the board. I see the edp cable on the...
          05-07-2025, 07:16 AM
        • Pwtzz
          Samsung 55NU6900 - Heard a pop then tv is dead, burnt cap & dead fuse
          by Pwtzz
          Hi All,
          Before replacing what I know to be bad even with my novice experience. What I have checked at the moment is the fuse and the obvious burnt capacitor. I haven't bought any replacement parts yet.
          I still have no idea how this happened but could just be plain old turned bad. What other stuff should I consider buying as replacement? thanks in advance.
          Edit: I saw that a replacement board can be had for about $50. I would rather attempt to fix before just replacement the board.
          07-19-2022, 06:45 PM
        • jesterace
          Samsung UE46ES8000 Blown fuse but no other signs of short
          by jesterace
          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
          09-11-2024, 03:14 PM
        • jshhh
          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
          by jshhh
          Hi guys,
          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
          Anybody know how to remove this type of fuse?
          (The fuse is toward the bottom of the image labeled F2)...
          06-17-2025, 01:35 AM
