controller board for LG LC420WUD-SBM4 LCD display
  • kevin_allein
    • Dec 2023
    • 45
    Hi, I have a 42 inch LCD from LG, part number LC420WUD-SBM4. This is from a broken TV (German brand Loewe, model Art 42 SL). I would like to misuse this LCD as a picture frame. That panel is a bit special, since it has 4 x LVDS channels with 10 bits each, but only WUXGA (1920 x 1080) resolution. I have been trying to find a controller board with HDMI interface for this panel, but was not successful. Any tips, where I could find one ?
  • lotas
    • Jan 2016
    • 4878
    • Russia
    This panel fits Main Board EAX60890803(3) for LG 42SL8000
    • kevin_allein
      • Dec 2023
      • 45
      Thanks for the answer, but this is another complete TV. I was hoping for a HDMI LCD Controller Board similar to that one: https://www.amazon.de/Controller-Boa...06WVMPWHP?th=1
      Again, I would like to misuse the panel as a picture frame.
      • kevin_allein
        • Dec 2023
        • 45
        Does nobody have any tips ?
        • diif
          • Feb 2014
          • 6978
          • England
          Have you looked on AliExpress ?
          • kevin_allein
            • Dec 2023
            • 45
            I did look on AliExpress. If I search for the panel name, only TCON boards show up. If I refine my search for e.g. 4 ch LVDS 10 bit, some boards come up, but no info, on whether timing could be adjusted, ... My experience with AliExpress is, that you usually get a board with no additional collateral, so no info how to adjust it. I also sent mails to some of those vendors, however no response from any of them. As I am not so experienced with LCD control I thought someone here might have additional tips.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
              Tankless hot water heater controller board not powering up when power is applied
              I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
              I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
              However I would like to know if I could figure what happened to this controller board if possible
              Tomorrow I will take some better pictures of both side of both boards
              The...
              12-09-2022, 09:14 PM
            • Grouickman
              EPILOG Laser - XS002 controller board
              by Grouickman
              Hello gus,
              Just have two XS002 controller board for Epilog laser engraver for repair, looking for any schematic or doc on those board. So far I could only find the "Service training manual", but it's for the whole unit, not specific to the controller board and there is very little info on the board itself.
              For instance I don't even have the connectors pinout
              thx.
              06-10-2025, 11:46 AM
            • WiredRacing
              Trials and Tribulations with M.NT68676.2 LCD Controller board and LVDS Panel
              by WiredRacing
              Hey all, want to poke the hive mind here for a technology I must be missing something critical about I can't discern from looking at spec sheets alone.
              I have an ATGames Legends Pinball machine, the playfield is a 32" LCD Display. I'm trying to attach an LCD controller to it for direct PC access, as others have been successful.
              The LCD is a SPLENDID CD320B01A-350 (I think it's a custom panel for ATGames as google turns up nothing), which is mated to a HV320FHB-N02 (47-6021088) T-CON board (this is probably the important component anyhow)
              The LCD...
              08-31-2021, 09:42 AM
