Burn in question
    Re: Burn in question
    Can you post a graph or list? The voltages should monotonically increase or decrease from VG1 thru VG## (whichever the limit is, 14, 18, 20, 22, etc.) I've not yet seen a TV with bad gamma voltages that wasn't fixed by new gamma IC. Perhaps you got a bad or recycled IC (removed from dud boards, etc. Common from China!)
    • tibimakai
      • Jan 2012
      • 3680
      The first atempt it wasn't succesful. I'm not sure if the IC did not get damaged then.
      • tibimakai
        • Jan 2012
        • 3680
        It was the AS15-F IC.
        Most likely, I didn't do a good job with the other chip.
        Unfortunately, I managed to rip up a pad.
        I have managed to replace successfully the IC and added a tiny wire from the IC's leg to the continuation of the ripped pad. Damn this job it was tiny.
        In the end, all went well and the TV it's working great now. Yeahh!
        Thank you for the help!
        • ttmi100x
          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
          by ttmi100x
          Greetings everyone,
          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
          Upon closer inspection...
          07-31-2024, 06:36 PM
        • karatzdi
          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
          by karatzdi
          I know some might say... just buy another one. Sell it as parts..!
          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
          Spent some time downloading the Service...
          06-11-2024, 08:38 AM
        • howardc64
          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
          by howardc64
          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
          • Backlight on, no image
          • Disconnect right buffer board (view from front), left side display comes on
          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
          • Buffer board is pretty simple
          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
          07-11-2025, 04:04 PM
        • Pinky Deepak
          Vizio M60-C3 Left Edge problem
          by Pinky Deepak
          I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
          Here's a video of both the issues: https://youtu.be/hMqc760nB3o
          09-27-2024, 05:11 PM
        • Tom41
          AOC U27G3X strange burn-in
          by Tom41
          I have an AOC U27G3X 4K gaming monitor that I use both as a TV and for gaming on a Nintendo Switch 2 console. Recently, something very strange has been happening to it. After playing a game that has an on-screen timer for a few minutes, the last digit of the timer (the one rapidly flickering from 0 to 9) appears to burn in on the monitor. Going to a different source or power cycling the monitor does not help; there is a constant flickering area on the screen where that digit was.
          It seems strange that only that digit would burn in, and NOT the other digits that are changing less frequently....
          10-23-2025, 04:33 AM
