Hitachi 40" LCD L40C205
  • SCITOMMY
    • Dec 2013
    • 35
    • US
    Re: Hitachi 40" LCD L40C205
    By the looks of your 1st picture, it looks like an Apple TV. Is it hooked up through HDMI? Have you tried another HDMI port or even HDMI cable?
    • Tjflyboy
      • Dec 2013
      • 16
      • British Virgin Islands
      HDMI works on another TV, this double picture is on all inputs into TV
      • Jaime Morillo
        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
        by Jaime Morillo
        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
        The TV was stuck on the logo and I couldn't access the update menu.
        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
        The image result was good, but the image is inverted.
        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
        08-18-2025, 11:38 AM
      • wolf1976
        hitachi 50hk5600 problem with display
        by wolf1976
        hi
        i have the above tv and the display starts distorts the display at only in applications like you tube
        after and on the didital channels
        now without connect the antenna only the image of itsselfs tv i have the image i have in attach
        i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
        can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
        09-13-2025, 02:26 PM
      • massimomax
        Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
        by massimomax
        Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
        spero che qualcuno può averlo per riprogrammare eprom. grazie
        Post in English !!!
        I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
        02-28-2025, 07:27 AM
      • dragometin
        Hitachi 40HYC42
        by dragometin
        TV Model: Hitachi 40HYC42
        Power Supply: 17IPS71
        MainBoard: 17MB95M
        Panel: VES400UNDS-2D-NO3
        When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
        I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
        Is there any variants on 17IPS71 power supply's?
        UART output pins 10 and 12 on scart connector:
        Code:
        12:24:04.595
        08-08-2024, 05:53 AM
      • fharris1977
        Hitachi L40C205 Backlight Inverter Repair
        by fharris1977
        Hello. I have this hitachi with no backlight and it needs this transformer. Does anyone know where this transformer is sold and can please provide a link if so? I have entered the part number with no luck....
        06-08-2020, 12:00 PM
