Sony Kv32S26 with no screen light.
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    I am presently repairing a Sony kV32s26 with no screen light.I have replaced Q601,Q602 and R607 in the PS and also the HOT.There in no heater voltage and therefore this can be the reason for the lack of screen light.Can anyone offer help with this problem?
  • R_J
    • Jun 2012
    • 9625
    Re: Sony Kv32S26 with no screen light.
    Do you have any voltages from the highvoltage transformer? I would check and resolder the pins on the horz. drive transformer, that is usualy the cause of the output shorting and taking out the power supply.
    Do you have B+ to the horz. output transistor?
    Do you have Horz. drive signal?
    You could possibly have a bad High voltage transformer, but usually if its bad it will short the horz. output transistor again.
    • SEAWOLF
      • Nov 2011
      • 177
      I have checked the flyback trans,soldered the horz drive trans.There is HV at
      the 2nd anode at the back of the picture tube.The voltage on the heater pin
      on the crt board is missing and therefore screen light is missing.The standby
      light is blinking continuously.
      • RON_CET
        • Jun 2012
        • 217
        Sony : Kv32s26 : No raster, hv normal, replace c366 10000pf
        also look @ vertical IC and go ahead and resolder those pins
        Ron Driver,BSEE,CET,ISCET,NESDA
        • R_J
          • Jun 2012
          • 9625
          The heater voltage comes directly from the flyback pin 6 to cn503 pin 1 (that voltage is ac at the horz. freq.) it then goes to the crt board and through a resistor 2.5 ohm to pin 8 of the crt.
          Do you have -15v on tp99 and +12v on tp98 ? they are supplies for the vert. ic. if not check r536 & r537 (.47ohm) if open the vert ic could be bad.
          No vert. deflection you will have no video.
          • SEAWOLF
            • Nov 2011
            • 177
            Thank you very much.
            • SEAWOLF
              • Nov 2011
              • 177
              Thanks for this information.
              • Ihandyrepair
                sony 55X850D black screen no front white or red led light.
                by Ihandyrepair
                Hi guys
                strange one
                I have a dead Sony 55X850D
                when plug in, black screen, no front white or red LED, no back light no screen
                Voltages I get
                3.3v LD/power and main board
                reg 12V
                reg 19V
                3.3v on power on pin
                no Tcon on
                no tcon 12v
                no BL_on
                I do get BL_ERR 2.0v
                I tried to bypass it by ground it but still get same symptom
                I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                or is possible the chip next to...
                08-07-2024, 04:58 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • Rav_tangle
                MacBook Pro 2011 turns on with keyboard light , screen dead
                by Rav_tangle
                Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                is this...
                05-31-2024, 04:09 PM
              • Alicat
                Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                by Alicat
                Stopped by this site trying to fix my parents Panasonic Plasma TV.
                Model number is TH-50PZ85U
                Power comes on and the red power light stays on solid.
                Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                I also hear a few clicks.
                I also think my parents said there was a thunderstorm and the TV failed after that.
                Section 6 in the service manual talks about power and no screen,...
                10-30-2024, 10:09 AM
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
