42 lg3000
  • sean-tek
    • Dec 2013
    • 6
    • United Kingdom
    42 lg3000
    Hi All,
    Iv just been given the above TV from my dad as its making a really annoying whining noise so he went and bought a new one. He said to me that the whining noise used to stop after around 15 minutes or so of being on. Now however it doesn't stop at all, I can vary the pitch of the whining by changing the setting of the backlight up or down. Or putting the TV into different picture modes ie sport, cinema etc.
    Now my suspicion is its the inverter board(s) having taken the back off and had a look the boards are as below. Now with the exception of this annoying noise the TV is working absolutely fine. Anyone else agree with my diagnosis or have any other ideas on what could cause the noise?
    Vit71053.50 logah rev 3
    Vit71053.51 logah rev 3
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: 42 lg3000
    Sounds like interferance from the invertor cable... I have it on a set here.... though yet to figure how the hell to stop it. If I move the inverter cables away from the speaker cables it quietens... Does yours do the same?
    • sean-tek
      • Dec 2013
      • 6
      • United Kingdom
      Re: 42 lg3000
      Hmm Il check when I next take the back off. Dad said it never used to do it and when it first started it would go after around 10 minutes. Unfortunately now it doesn't go. I found a pair of the inverters on ebay for £29 with a warranty so iv bought them. Will try fitting them when they arrive and let you know if that cures it
      • seanc
        • Nov 2008
        • 1319
        Re: 42 lg3000
        My parents 42LH3000 does this when displaying blue or black - e.g Sky HD EPG or blue screen as you change channel. Bugs me but they don't notice.
        • sean-tek
          • Dec 2013
          • 6
          • United Kingdom
          Re: 42 lg3000
          So after replacing the inverters its still doing it, however it stops after about 2 minutes of use, then it wont return until I turn the tv off and leave it 5 minutes, then another 2 minutes of this noise followed by silence. Iv just ordered a new PSU board to see if that will solve it failing that il just put up with it
          • T-con
            • Dec 2013
            • 57
            • Taiwan
            Re: 42 lg3000
            Maybe a psu problem, sometimes the trafo makes hi freq. noise when capacitors are leaky.
            • sean-tek
              • Dec 2013
              • 6
              • United Kingdom
              Re: 42 lg3000
              Unfortunately not a psu issue either although on the plus side I now have a spare set of inverters and a spare psu board. Although absolutely no idea whats making this noise
                Re: 42 lg3000
                Try using a cardboard tube to isolate source of sound?
                Tried unplugging speakers to see if it goes away?
                • sean-tek
                  • Dec 2013
                  • 6
                  • United Kingdom
                  Re: 42 lg3000
                  Sound is still there with speakers unplugged, il go round it with a cardboard tube tomorrow although due to the frequency of the noise it kind of sounds like its coming from everywhere :-( it definitely changes frequency when I adjust the backlight settings like set it to movie, sport etc. The best way I can describe it is similar to the sound of the flash charging on an old disposable camera but louder.
                  • MegaZAC
                    Onkyo TX-SR805 noise in one channel
                    by MegaZAC
                    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                    There's some logic behind it. As soon as I select an input I get only left...
                    04-23-2025, 10:09 PM
                  • x_orange90_x
                    Seven Leagues Slot Machine stop button issues
                    by x_orange90_x
                    I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
                    The issue now is the Stop buttons are intermittently...
                    02-12-2025, 10:01 AM
                  • courtcircuit
                    Philips HTS8000 home cinema noise problem
                    by courtcircuit
                    Hello
                    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                    Removed each of tyhe boards
                    02-08-2025, 08:22 AM
                  • Cyo
                    Power Supply FM TOWNS TDK loud whining noise
                    by Cyo
                    Hi!
                    As you might guess I'm having a problem with a very old power supply. When I got my FM TOWNS computer the power supply had a lot of corrosion from leaning capacitors. I bought replacement capacitors and cleaned the board extremely thoroughly. Soldered them in and my PC came to life! I was excited!
                    About a month later I turned the computer on and it makes a loud whining or hissing noise for about 20 seconds and then shuts off and won't come back on. It will come on for about half a second and the front lights will light up then it will shut right back down. I'm...
                    09-16-2020, 06:41 PM
                  • karatzdi
                    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                    by karatzdi
                    I know some might say... just buy another one. Sell it as parts..!
                    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                    Spent some time downloading the Service...
                    06-11-2024, 08:38 AM
