Power Supply FM TOWNS TDK loud whining noise
  • Cyo
    • Sep 2020
    Hi!
    As you might guess I'm having a problem with a very old power supply. When I got my FM TOWNS computer the power supply had a lot of corrosion from leaning capacitors. I bought replacement capacitors and cleaned the board extremely thoroughly. Soldered them in and my PC came to life! I was excited!
    About a month later I turned the computer on and it makes a loud whining or hissing noise for about 20 seconds and then shuts off and won't come back on. It will come on for about half a second and the front lights will light up then it will shut right back down. I'm not so sure where to start as far as troubleshooting as these old Japanese computers aren't well documented in the West. I've replaced one IC I've heard others had issues with on another forum along with 3 small transistors but the symptoms haven't changed.
    I know some people just wire an ATX PSU and throw it in but I would like to salvage this and revive my PC. What should be my next route based on these symptoms?
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
  • Biruslapio
    LG 50PB690 power supply terrible noise
    by Biruslapio
    I bought this TV with really bad oxidation on the power supply and bottom X boards, it was working but during pickup there was a lot of background noise so I don't know if it had this problem before.
    As soon as I could I opened the tv and started working on it, did not test it before since it had back bars on the screen and obvious signs of humidity. The X boards were replaced and the screen now works 100%, but the power supply...
    I washed the board and resoldered almost everything on the primary, the oxidation happened because of constant mains AC current flowing,...
    07-13-2022, 12:46 PM
    07-01-2024, 06:34 AM
  • eliemgh
    lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise
    by eliemgh
    lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise for about 3 seconds and power light is on. Nothing on display screen. i have removed the battery and bios battery still the same. i have put yesterday on update and charger ,i have leave and back and see this problem. Any One Can help Me ?
    09-27-2024, 02:40 AM
