PD50G1 -Vy Testing Positive Voltage
+ More Options
Posts
  • ChrisV
    • Dec 2013
    • 66
    Troubleshooting a plasma with no picture. Looking at the YSUS, the -Vy target is -195. My actual is +195v with only the bottom buffer board attached. There is no voltage on VA or VSC with upper buffer board in place.
    I'm thinking, I have a bad upper buffer board. What would cause the -Vy to test positive?
    Thanks for any help that is offered
    Re: PD50G1 -Vy Testing Positive Voltage
    Such a positive -Vy would certainly be explosive to any capacitors nearby, so I doubt it's the case. Just need to reverse probes.
    • ChrisV
      • Dec 2013
      • 66
      Thank you for the reply Tom66.
      Just for clarification, if I check voltage in the way that is described in the photo above, with red probe on + and black probe on -, it is a positive voltage. If I reverse the probes and place the red on the - and the black on the + it has the correct negative voltage.
      Could there be something wrong with my DMM or would this indicate correct voltage at this test point?
      Thanks again.
      PS - Thanks for making the service manuals available
        I think it's a mistake in the service manual. Nothing to worry about.
        • ChrisV
          • Dec 2013
          • 66
          Thank you Tom
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            Today, 07:19 AM
            MAX9590ETU+ MAX9590 Datasheet
            The MAX9590 provides 14 programmable voltage references and four static voltage references for gamma correction in TFT-LCD displays. Two register banks are provided to store two sets of gamma reference values. Gamma values are programmed into the banks through the I2C interface and the outputs can switch between values in 0.5µs.
            The 14 programmable reference voltages are divided evenly into seven upper and seven lower voltages for the upper and lower gamma curves of LCD column drivers.
            Each gamma reference voltage has an 8-bit digital-to-analog converter (DAC) and isolation...
            10-07-2024, 04:18 AM
            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
            by sam_sam_sam
            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
            Now...
            06-09-2024, 10:57 AM
            ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
            3+1 Voltage Regulator for IMVP-7/VR12 CPUs
            Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
            core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
            configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
            serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
            Based on Intersil's Robust Ripple Regulator...
            11-05-2024, 03:24 PM
