Atec AV420D No Standby
    Re: Atec AV420D No Standby
    so it's more than likely caps rather than fets?
      A FET would not fail intermittently.
      You can still do a check for cold solder joints.
        i've got a fair few cable boxes and old boards laying round, might see if i can match the caps and replace to test at least then order some pannys at a later date
        tom once again you've been more than helpful, top guy!
          I really wouldn't advise that. Old capacitors can "form" to a voltage, which means they can fail to work correctly in a new circuit, even if they worked in the old one. Some capacitors can also dry out if they are left for a long time which may mean they fail too. Just wait a few days for those caps -- it shouldn't cost more than a few pounds and surely all the time soldering/resoldering caps is not worth it.
            I really wouldn't advise that. Old capacitors can "form" to a voltage, which means they can fail to work correctly in a new circuit, even if they worked in the old one. Just wait a few days for those caps -- it shouldn't cost more than a few pounds and surely all the time soldering/resoldering caps is not worth it.
            i'll wait then, i do have some new caps already but there all big ones so guess there not the right ones
            i'll check for colder solder joints at least anyway
              You don't have to replace the 450V cap though.
                oh right my mistake, think i've narrowed it down to 2 100uf 50v caps
                  tom just a quick one to say thanks again
                  got the new caps today fitted and tv works as it should now
                  have a good christmas and a even better new year all the best
                    Glad to hear. Have a good Xmas.
                      Hello,I have a similar problem just I have a standby light on all the time ,could you help me to fix the board ,thank you in advance .
