Atec AV420D No Standby
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Re: Atec AV420D No Standby
    so it's more than likely caps rather than fets?
      A FET would not fail intermittently.
      You can still do a check for cold solder joints.
      • anotherdude
        • Feb 2013
        • 488
        • uk
        i've got a fair few cable boxes and old boards laying round, might see if i can match the caps and replace to test at least then order some pannys at a later date
        tom once again you've been more than helpful, top guy!
          I really wouldn't advise that. Old capacitors can "form" to a voltage, which means they can fail to work correctly in a new circuit, even if they worked in the old one. Some capacitors can also dry out if they are left for a long time which may mean they fail too. Just wait a few days for those caps -- it shouldn't cost more than a few pounds and surely all the time soldering/resoldering caps is not worth it.
          • anotherdude
            • Feb 2013
            • 488
            • uk
            Originally posted by tom66
            I really wouldn't advise that. Old capacitors can "form" to a voltage, which means they can fail to work correctly in a new circuit, even if they worked in the old one. Just wait a few days for those caps -- it shouldn't cost more than a few pounds and surely all the time soldering/resoldering caps is not worth it.
            i'll wait then, i do have some new caps already but there all big ones so guess there not the right ones
            i'll check for colder solder joints at least anyway
              You don't have to replace the 450V cap though.
              • anotherdude
                • Feb 2013
                • 488
                • uk
                #27
                oh right my mistake, think i've narrowed it down to 2 100uf 50v caps
                • anotherdude
                  • Feb 2013
                  • 488
                  • uk
                  #28
                  tom just a quick one to say thanks again
                  got the new caps today fitted and tv works as it should now
                  have a good christmas and a even better new year all the best
                    Glad to hear. Have a good Xmas.
                    • matyka
                      • Jan 2015
                      • 179
                      • Uk
                      #30
                      Hello,I have a similar problem just I have a standby light on all the time ,could you help me to fix the board ,thank you in advance .
                      • ChristianBr01
                        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                        by ChristianBr01
                        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                        04-23-2025, 01:48 AM
                      • AleMonti
                        LG 55EG910V - no power and no standby light
                        by AleMonti
                        I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                        I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                        The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                        After checking the basics I did the following:
                        • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                        11-04-2024, 05:02 PM
                      • Kaar3l
                        Samsung QLED QE65Q7FNAT only standby light
                        by Kaar3l
                        TV: Samsung QLED QE65Q7FNAT
                        PSU: BN4400940A
                        MB: BN94-12832K
                        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                        09-24-2024, 01:35 PM
                      • jasonbay13
                        Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                        by jasonbay13
                        picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                        am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                        12-01-2023, 09:55 PM
                      • Nicktronic
                        Samsung UN70NU6070F Standby Light flashes twice
                        by Nicktronic
                        Hey Everyone,
                        So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                        I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                        03-27-2023, 07:01 PM
