Atec AV420D No Standby
  • anotherdude
    • Feb 2013
    • 488
    Picked this up yesterday for £30 fault was described as "won't turn on it used to turn on after 20 minutes but now theres no standby light"
    So i took the psu out and removed the old fuse near the 250v input and replaced it with another I had off a faulty board.
    It now gets a standby light for all of 5 seconds then konks out, no sign of any other damage anywhere
    top of caps get low voltages and gradually drop as the standby light dissappears
    samxon caps too
  • anotherdude
    • Feb 2013
    • 488
    Re: Atec AV420D No Standby
    found this thread that tom66 fixed https://www.badcaps.net/forum/showth...highlight=atec
    there not the same psu so not sure it's the same fault
    what should i be looking for if standby voltage disappears?
      Check if the PSU 5V standby is stable or not.
      • anotherdude
        • Feb 2013
        • 488
        at the stby 5v pin i get 4.96v so would appear to be stable?
          Check what the PSON signal is doing.
          • anotherdude
            • Feb 2013
            • 488
            sorry tom i appreciate your help but i can't seem to see anything labelled with PSON
            better image of the board
            • anotherdude
              • Feb 2013
              • 488
              ok was going through checking all the pins for voltage to see if they were correct and funnily enough the screen turned on and it worked but theres a flicker to the screen including menus too. turned it off and back on and now no picture again and no standby light
              so seems it has to get warmed up so to speak before it will turn on, caps?
                D5-ON might be the pin.
                • anotherdude
                  • Feb 2013
                  • 488
                  ok when i power on the standby light comes on at the d5-on pin i read 1.45v and when the standby light disappears it drops to 0.03v
                    OK, and what do the D5V, D12V do during this?
                    Seems like main board fault.
                    • anotherdude
                      • Feb 2013
                      • 488
                      from power on D5V gets to 2.20-2.40v and continues to drop to 1.20v and slowly continues to drop
                      D12V after the standby light disappears sits at 0.63v
                        That is bad, then. On the power supply.
                        Take a 100 to 470 ohm resistor and connect it between 5V standby and D5 ON, do the main voltages rise?
                        • anotherdude
                          • Feb 2013
                          • 488
                          12v still sits a 0.63v with a 100ohm resistor connected to 5v stby and d5 on
                            Try warming up the PS board with a hairdryer to see if that increases; also try isolating all connections from the PSU board.
                            • anotherdude
                              • Feb 2013
                              • 488
                              ok tom your on to something
                              gave it some heat at first i was hearing popping from the speakers and the voltage on 12v was rising i continued with the heat until it hit 12v and the screen turned on and the popping disappeared
                              assuming bad caps now from previous experience?
                              also the screen flickering has gone
                                I'd try focusing heat on the capacitors on the primary side, over the ones on the secondary.
                                • anotherdude
                                  • Feb 2013
                                  • 488
                                  so the side with the majority of the caps?
                                    No, that's the secondary. Primary has the mains voltage on it. i.e. do not touch, hurty electric side.
                                    • anotherdude
                                      • Feb 2013
                                      • 488
                                      ok tom i've narrowed it down to this
                                        I would replace all the small caps in that area. In fact I'd also replace the two near IC6, too.
                                        Now CPC offers free delivery from £0.01 and stocks Panasonic caps, I'd not order anywhere else:
                                        http://cpc.farnell.com/
                                        Won't arrive before Xmas though.
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • jasonbay13
                                          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                                          by jasonbay13
                                          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                                          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                                          12-01-2023, 09:55 PM
                                        • Nicktronic
                                          Samsung UN70NU6070F Standby Light flashes twice
                                          by Nicktronic
                                          Hey Everyone,
                                          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                          03-27-2023, 07:01 PM
