Screen not coming on - LG 55LD520-UA
  • kingkiller
    • Aug 2013
    • 28
    Re: Screen not coming on - LG 55LD520-UA
    Well, I put it up on Craigslist to be sold as is and the best offer I could get is $100, and I think I'm going to take it. That's about all I could probably get parting out the boards and stuff after PayPal fees, etc., and with less hassle. Thank you bad caps for your help troubleshooting this one. I wish we could have figured out the root cause of the problem, but either way I learned a good amount about these things in the process.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
    • ipatch
      ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
      by ipatch
      i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
      08-24-2024, 02:36 PM
