Picked this up for $30 and a box of extra boards because this kid gave up on fixing it (red flag right there). Anyway, sound with no picture, blah blah. I read on here a hundred times, Y main and buffers. I replaced those and yes it fired right up with 1079 beautiful lines of HD video. However, I insist on all 1080 lines so I reseat the buffer cables a few time and still have one dead line. i notice now that the ribbon cable on the bottom is severed across one of the traces just about where the missing line is. I'm hoping this cable can be replaced or is this a deal breaker? Also have one black vertical line as you can see by the pics. Any advice, Godfathers of TV repair?
LG 42PC3D 1 lane severed on Y Buffer ribbon
Re: LG 42PC3D 1 lane severed on Y Buffer ribbon
Here's a successful repair to the Y-buffer ribbon, but it's an extreme long shot: https://www.badcaps.net/forum/showth...=Ribbon&page=2
The vertical lines point to a panel issue. -
Just a note: this is a 1024x768, 720p TV. Not 1080p.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Someone was careless when removing the ribbons from the y and x drivers.. Have you taken a magnifying glass and lookek for cracks or a broken line in the cables? Creases in the cables or the sort? I have had luck repairing this fault before fut its not easy. However I have also made matters worse on another set I tried to repair this fault on as well and shorted out the whole x driver IC.. If you cannot find the fault in the ribbons, sometimes its just not worth it.Did I leave the soldering iron on?Comment
That intersecting fault to me looks like one bad pixel has damaged the connection to the others.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Finally got my buddy over here who is an expert soldered and he rigged up a microscope on the damaged ribbon, scraped the insulation off 3 or 4 lanes of the ribbon. Then he soldered little wire jumpers across the damaged lanes. First he did one side and rtv'd down and let it cure for a day, then soldered the other side down and coated that with rtv. It took care to the horizontal lines but I still have one vertical line on the right hand side, black and 1 pixel thick from top to bottom. Re seated the cables all over the place many times but can't get rid of it. Don't tell me it's the panel after all this surgery.Comment
Sorry, those lines look like panel to me...
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by zeskoHello,
I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
There is 2 models, idk which one is needed on my laptop.
0xkvng
00vpr2
Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
thanks...-
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by YanlebHi all,
I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer.... - Loading...
