RCA 42PA30RQ abnormality
  • Maushinator
    That Guy
    • Dec 2013
    • 50
    Re: RCA 42PA30RQ abnormality
    No, the voltage holds steady. Tested it for about 2 minutes straight only randomly changed .1v either way.
    • Maushinator
      That Guy
      • Dec 2013
      • 50
      Yes, rapidly actually.
      • Maushinator
        That Guy
        • Dec 2013
        • 50
        My eyes played a trick on me.. The voltage drops rapidly with the buffer connected. without the buffer it held voltage +/-.1v
          The buffer is definitely bad then.
          • Maushinator
            That Guy
            • Dec 2013
            • 50
            I have the new one, shall I swap it out and see what happens?
            • Maushinator
              That Guy
              • Dec 2013
              • 50
              So I swapped boards.. Not good. With my unit unplugged I connected the ribbons and slid it into the Y main. A little spark emitted from the connector closest to the top (I thought that was normal) tightened the buffer down turned the TV on and... Back to safe mode
              • Maushinator
                That Guy
                • Dec 2013
                • 50
                I probably should have tested the board before I installed it there is a few .01 readings on the pins
                  Was it powered up while you made the connection? Small spark is OK, but the new buffer may have been shorted. Y-buffer boards from cracked plasmas tend to be bad. I'd have to say at least half are. It's just the luck of the draw. I pulled one which is very bad. See here to test (board from PS42B450, similar to your set.)
                  http://www.youtube.com/watch?v=51SZsfH60EY
                  • Maushinator
                    That Guy
                    • Dec 2013
                    • 50
                    Could the panel side be shorting the buffer?
                    I mean I can't find any apparent issue/s with the Y main... Unless there's something I haven't checked.
                      There is a small chance the panel is bad but it is unlikely.
                      • Maushinator
                        That Guy
                        • Dec 2013
                        • 50
                        My meter never beeps but here's an example of what I found. Let's say 1200 across each pin, then all the sudden .1,.1,.1 then back to 1200 on the pins for the same chip.
                        Both my boards are like that. Different chips though. The new buffer I just got has the same model and PBA number, but different REV and PCB. Is that okay?
                        • cheeky2
                          by cheeky2
                          05-25-2024, 03:27 AM
                        • Dani_2024
                          by Dani_2024
                          10-28-2024, 05:06 PM
                        • ygorsan
                          by ygorsan
                          🧩 Problem Summary:
                          • I
                          07-28-2025, 08:34 AM
                        • Asraf Atb
                          by Asraf Atb
                          01-27-2025, 05:02 PM
                        • JSin21
                          Compatibility of main boards between different variations of samsung MU6100
                          by JSin21
                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                          11-27-2023, 04:54 AM
