RCA 42PA30RQ abnormality
  • Maushinator
    That Guy
    • Dec 2013
    • 50
    More or less I'm stuck. I am getting power but no video except for a brief static session when I first power up the unit. The screen has a slight glow to it, I have no shorts in the diodes or transistors on the X or Y main and nothing pops up on the PDP test. Does anyone have any suggestions on what to do from here?
    Any help would be greatly appreciated.
  • Maushinator
    That Guy
    • Dec 2013
    • 50
    Re: RCA 42PA30RQ abnormality
    VA voltage at power on @120 (supposed to be 55) with voltage drop to 0. VS @ normal also with voltage to 0. That is with and without the Y main connected.
    EDIT: I Also PS&VS on checked to be good.
    • Maushinator
      That Guy
      • Dec 2013
      • 50
      I just tried to do a PDP test again (jumped 3 and 4 and disconnected LVDS from the main) but I also jumped the VS on to the ground still no result on the PDP. The relay clicked as it should have but still nothing displayed on screen. I then tested the VA @0v the VS was @ 6v the VE on Y main @ 6.1v and the VE on X main was @ 0.
      I don't know if any of this information is helpful to anyone but I'll keep posting my findings..
      • Maushinator
        That Guy
        • Dec 2013
        • 50
        Update: So I realized I didn't disconnect the ribbons upon testing the VA/VS.. So the VA rated at 55v is actually reading and holding 120v. The VS rated at 207v is reading and holding 464v. Does that mean my PS is bad because it's not regulating the power output?
        • Maushinator
          That Guy
          • Dec 2013
          • 50
          Or my control board is bad because that's what regulates my PS output?
          • Maushinator
            That Guy
            • Dec 2013
            • 50
            The light flashing at 5 second intervals flashes at the normal 1 second interval with the Y main ribbon disconnected. With the Y main disconnected and the power connected the X main hums and the VE is reading 220v.
            • Maushinator
              That Guy
              • Dec 2013
              • 50
              With that said signs point to either the Y main and/or buffer as the problem?
              But what about the high voltage issue?
              100% lost once again...
              • newtothis
                • Mar 2013
                • 1556
                • england
                As I said my knowledge of Plasma displays are limited... but a tip to obtain help... Don't keep posting on your own thread like that or people will think you are being helped out by someone
                • Maushinator
                  That Guy
                  • Dec 2013
                  • 50
                  Noted. It's my first thread I figured I would try to be as informative as possible whilst I sit here like
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    Just need to wait until one of the Plasma Techs comes along, Be patient.. help will arrive
                    • Maushinator
                      That Guy
                      • Dec 2013
                      • 50
                      I have 2 low readings on my Y buffer board in comparison to the rest of the connectors in the line. I'm just going to order a new Y buffer to see if that fixes the problem. I had everything connected except for the Y buffer and the LED on the control board flashed normally. As far as my power problem goes.. Who knows. Does my assumption sound correct?
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        Tom, What do you think.. you have more knowledge than me on these
                        • Maushinator
                          That Guy
                          • Dec 2013
                          • 50
                          I just had another idea. Maybe reconnect the Y buffer but leave the panel disconnected and to see if the LED on the control board flashes in safe mode again...
                          • capkid
                            • Oct 2010
                            • 1339
                            Your voltage readings don't seem to be measured correctly. VS of 464V sounds ridiculously high, and I'd expect to see some serious damage as a result.
                            LG Plasma Mal-Discharge Correction Service
                            • Maushinator
                              That Guy
                              • Dec 2013
                              • 50
                              You would think but it doesn't make sense for them to be that high... I mean nothing gets hot as you would think it would if the voltages are indeed that high. I would think the damages would be immense. This might be a stupid question but the voltages should be tested in AC right?
                              I reconnected the Y buffer board without the panel connected and the LED on the control board flashed back in safe mode so I officially ordered the Y buffer board.
                              • capkid
                                • Oct 2010
                                • 1339
                                No, the voltages output by the PSU are DC. Either way, a buffer board might be a good place to start if you in fact don't have any shorts on the Y-main or X-main.
                                • Maushinator
                                  That Guy
                                  • Dec 2013
                                  • 50
                                  Figures, I'll recheck the voltages tomorrow and post back the results. No shorts in the boards for sure. I even checked the tiny diodes on the bottom side of the boards. I read somewhere that the LED on the control board only flashes in 5 second intervals if it indicates a problem with the Y main, the X main and/or the Y buffer. So, on or before 12/26 I'll find out if replacing the Y buffer fixes the problem.
                                    Glowing screen: try this:-
                                    https://www.badcaps.net/forum/showpo...61&postcount=2
                                    Also, check VA fuse on E/F buffer boards.
                                    • Maushinator
                                      That Guy
                                      • Dec 2013
                                      • 50
                                      Tom, I tried the PDP that way and I also tried that but also disconnecting a plug coming off the PS to the control board (on the control board side and placing a jumper wire from VS on to the circuit ground and nothing at all showed on the panel either way.
                                      Edit: I haven't removed the E/F buffer boards. They seemed difficult to get to but I'll look more into it in a few hours.
                                      • Maushinator
                                        That Guy
                                        • Dec 2013
                                        • 50
                                        There is no fuse on either the E or F buffer boards. The voltages for VA and VS are normal upon testing them in DCv
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
