I had a question about a dp50747-01 Sanyp plasma TV. I'm getting the typical "powers on then relay clicks and it shuts off". I replaced 9 bad caps on the power supply board that now I get a brief flash of the screen before it shuts right back off...it didn't do that before. I'm looking at the 4 led lights on the logic board and am not sure what they mean. They are labeled as D2 through D5. When I initially power it on, they all light up, then all go out but D2. After a few seconds along with the relay that clicks and it powers off, D2 goes out too. I get these symptoms over and over. Any insight?
DP50747 Question
Re: DP50747 Question
A quick update to this as I had a couple of details wrong before...it is D3 through D5 that light up and go out, D2 is never lit. Does anyone know what D2 represents?
Also, I've tested the power supply, Vs is getting the correct voltage, but I'm not getting anything on Va at all. I'm still getting a slight flash of the screen each and every time I try powering on. Any suggestions? I appreciate the help! -
OK, I tested all of the points that were referred to in that manual you sent me, and the only 2 things that didn't come back correct were the pin 36 on the IC801 CPU (pin 32 was correct, and I'm not sure if I was supposed to get a reading on pin 36) and also the D1621 on IC1620 is coming back at about 7 volts (instead of 33v). These were all tests on the Power Failure Circuit page. I did notice that there was no chip in the D1683 spot (on K8B at 12V) but I did measure the little solder pad that was in its place and got about 5 volts (the manual said I should be getting 12V).
I believe I'm testing these right...black lead on ground and red lead on the chip's solder point, like D1621.Comment
by RensieeHello,
I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
I have measured the voltage in the VSUS line, which...06-18-2024, 12:58 PM -
by momakaI got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
Problem:
Backlight cycles On and Off.
Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark.... -
by samtron786Hello
The red and green LEDs both light up and you can hear the relay click. (no picture, no backlight, no sound)
2-3 seconds later the relay will click again and only the red LED will stay on.
I would be very grateful for any advice or a little help.
circuit diagram?
Thanks very much -
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by jm1234Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but... - Loading...
