I have a Vizio i just ordered a new "X" board for(atleast thats what its being called) I assumed it would be the "Z" board but its not. Anyways, I was able to get the tv to power up and display a picture. Now the picture is showing a lava lamp effect which points to the "X" board again. The 2 Ribbon cables going to the "X" board are sparking on the frame. When i adjust the voltages on the X and Y board, picture improves but doesn't fix the bad color. Main voltage on the Y board was 180-186. If i lower the voltage to 120, it fixes the lava effect after a few moments. I've checked the service manual with no help. Thinking it might still be the X board. But looking to see if anyone else has had this tv with the same problem. THANKS!!!
Vizio VP422HDTV10A picture problems
Tags: None
Re: Vizio VP422HDTV10A picture problems
Can you show us a picture of the fault?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
I apologize for the late response. I work 50 hours a week or more during the holidays. The first picture is before I turn down the voltage on the y sustain board. The second picture shows how it clears up but even if something is on the screen, I still have color distortion.Attached Filesif you find these attachements useful please consider making a small donation to the site
That could be an X- or Y-main fault. To locate the exact fault the voltages on the various boards need to be tested; please post a picture of the X- and Y-main boards (right and left hand boards, looking from rear of set)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by gavricHello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
When tv powers on vizio V logo shows nice on whole screen. picture 1
When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
When i start youtube picture shows on left side fine, right is all scrambled. pic 2
When i click video to start playing picture goes black(like when you change... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by ermalsHi all!
I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
3. I've checked voltages... - Loading...
