I got this Samsung ps42b430p2wxxu, Symptoms are it's clicking on and off repeatedly. I took off the cable "pic1 pen pointing too" And the tv started up. So I think im right in assuming it the y sus board at fault. The guy said he turned off the set strait away once it went bad so im gonna assume the x board is ok. looking at the y board there is no obvious fault but I did some component tests and this diode is measuring 0.6 with red on anode black on cathode and 1.13 the other way around. Resistance is measuring 10.2k black on anode and 10.4k the other way. I thought with a diode you only get current one way. looking at the top view pic there is nothing else in the net to confuse readings.
Am I right to assume this diode has shorted?
