Y sus problem diode maybe?
  • snipersquad100
    • Nov 2013
    • 297
    I got this Samsung ps42b430p2wxxu, Symptoms are it's clicking on and off repeatedly. I took off the cable "pic1 pen pointing too" And the tv started up. So I think im right in assuming it the y sus board at fault. The guy said he turned off the set strait away once it went bad so im gonna assume the x board is ok. looking at the y board there is no obvious fault but I did some component tests and this diode is measuring 0.6 with red on anode black on cathode and 1.13 the other way around. Resistance is measuring 10.2k black on anode and 10.4k the other way. I thought with a diode you only get current one way. looking at the top view pic there is nothing else in the net to confuse readings.
    Am I right to assume this diode has shorted?
  • tw2005
    • Oct 2011
    • 6458
    Re: Y sus problem diode maybe?
    See what results you get with these steps.
    • snipersquad100
      • Nov 2013
      • 297
      if the answer is no to Q1 then I change the y board, is there any point in doing test 2 and 3?
      • tw2005
        • Oct 2011
        • 6458
        I'd try it just to see if the clicking comes back. I don't know how reliable that fault finding is, just something I found.
        Although it's in logical sequence so the result may be void, I really do not know,
        last samsung i touched which was the 2010 series needed x & y as the x shorted the y too.
        That model had a known x-main issue and firmware upgrade. ps42c451b2
        have not touched many Samsungs so I can't guide you with any real experience on them.
        Maybe find what other models use the same boards and try a search in the forum to see if anyone has had a similar fault.
        • snipersquad100
          • Nov 2013
          • 297
          This diode here is reading 0.0012 both ways on a diode test. surely its a faulty diode???
          • NicRac
            monowheel repair,Is the diode the problem?
            by NicRac
            Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
            First of all, I am new here. Therefore I will shortly introduce myself.
            I am Nico and currently I study Physics.
            In my freetime I like to build and repair stuff. Especially big battery's.
            A few years ago I got myself an electric unicycle, monowheel or however you call that.
            The battery bms was broken so I replaced and resolder that. Nothing big.
            I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
            07-26-2024, 06:13 AM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
          • PantherDave
            by PantherDave
            Hi all!
            I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
            05-29-2024, 02:01 PM
          • Gibon378
            Problem with stopping audio and video for no reason
            by Gibon378
            PC Specs:
            • CPU: Ryzen 5 1600
            • GPU: GTX 1080 Palit JetStream
            • MOBO: ASRock ab350 PRO4
            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
            • PSU: XFX 650W (don't remember what model)
            • OS SSD: ADATA SP920
            • OS: Windows 10 21H2
            Problem description:
            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
            11-19-2022, 09:41 AM
