ID an LCD or a Plasma from outside?
  • Ahakim
    • Apr 2013
    • 64
    How to tell whether it's a plasma or an LCD TV, without opening the set? What is the fastest way to identify it?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: ID an LCD or a Plasma from outside?
    what do you mean by picture only and not physically in front of the TV? Physically touch the screen is it made of plastic material or is if its plastic in the screen is completely black its lcd. if the screen is glass its plasma. a tell tale sign is a color the screen LCD seriously pitch black in have a matte finish plasmas are shiny gloss like glass
      Many plasmas have a grey or blue tint to the panel when off. Almost every LCD is black. Also all 42" 720p/480p plasmas will have visible electrode lines unlike LCDs.
      • 120volts
        • Oct 2013
        • 57
        I've found that all plasmas I have seen have a glass screen
        and I have not seen an LCD with a glass screen yet. Yes Lcd screens have glass layers in them but never have the 1/8" thick front layer like plasmas do.
        Dan "TV Tinkerer"
        • ArMaaN376
          Samsung PS51E550 Plasma TV
          by ArMaaN376
          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
          Opened TV cover & observed foll
          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
          How to confirm Y -Buffer board...
          06-19-2024, 04:05 AM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • KYBOSH
          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
          by KYBOSH
          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
          No picture but you hear the TV static (white noise) playing loud and clear.
          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
          But it seems they didn't get too far and just left it.
          When I first took a look I was amazed at how pristine the inside looked.
          Its as if the TV had been in a time capsule.
          Caps looked like they were just pulled off the self.
          Copper coils had no sign of corrosion on...
          02-01-2023, 11:10 PM
        • chazh
          LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
          by chazh
          This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
          I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
          The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
          09-01-2025, 08:56 PM
        • porfyriadhs
          Samsung Plasma PS51D6900DS Bootloop
          by porfyriadhs
          Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
          Thanks a lot !!
          10-19-2023, 11:31 AM
