LG 42LF11-UA half screen issue
  • frake3
    • Dec 2013
    • usa
    So I have been troubleshooting the old half screen out / vertical colored lines issue now and want to make sure this is not a panel issue.
    LG 42-LF11-UA
    Synopsis:
    Turn the TV on and the whole left side is out. After 5-10 minutes colored vertical lines that somewhat match the colors or the visible right side appear. If I tap on the upper left corner of the screen the picture will return to normal. After a sporadic amount of time the bars will come back.
    I ordered a TCON board and when I installed it the issue was not resolved and in addition it seems that pink and reds are replaced with a green color.
    So questions are: Another bad TCON board? Wrong TCON board (although the site I ordered from specifically listed my model) Bad panel? Something else??
    Looking for additional troubleshooting steps from this great knowledge base. Hoping it is not a panel issue.
    thanks!
    Re: LG 42LF11-UA half screen issue
    Tab bonds/panel issue, but luckily on these not too bad to fix, quite high success rate.
    Probably same panel but different TV: http://www.youtube.com/watch?v=purk_SyiT44
    • frake3
      • Dec 2013
      • usa
      Thanks so much that did the trick. The hard part was getting the right thickness of the pieces of material. The half screen issue is gone but now there is a single black line going down the left center of the screen. Did I brake something?
      Thanks again for your assistance.
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • wizard13
        Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
        by wizard13
        I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
        I have checked the forum and the available documentation but could not find a solution specific to my issue.
        • Brand & Model: Dynabook Satellite Pro C50D-B-100
        • Part Number (P/N): PYU13E-00C00PFR
        • Serial Number (S/N): 22028896H
        • System Configuration (SC): A1PYU13E1127
        • Motherboard Model: IP3_ACN16_MB_V21_20211222A
        • Power Input: DC 19V –
        02-28-2025, 02:43 AM
