Desperately seeking Panasonic TNPA5105 SC board.
  • ecxone87
    • Dec 2013
    10 blinks of death Panasonic TC-P50U2 thanks to the forums found a trouble shooting guide for the P50U1. Followed the chart says SC board is bad, problem is can't find one anywhere.
    Does anyone know if the part is discontinued or have any leads where to get one?
    Also if anyone has a copy of the Panasonic 2010 trouble shooting guide can you post it? About to by a new TV my PS4 is getting lonely.
    ShopJimmy P/N - Panasonic TXNSC1LQUU SC Board
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
    After all of...
    07-13-2024, 08:14 PM
  • canadaboy25
    Panasonic TC-P54VT25 No image. A or D board?
    by canadaboy25
    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
    01-17-2021, 01:06 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
