baird j047 no power
  • wreksta
    • Aug 2013
    • 508
    • england
    baird j047 no power
    hi all got this set in today
    someone has taken away the rocker switch from the bottom I replaced power board with a known working one and I have no light no power no nothing but the thing is its wired straight from ac input to the power board no switch inbetween
    I was wondering if anyone has any pictures of this rocker switch
    or can shed some light on this
    Re: baird j047 no power
    If the rocker switch is bypassed the set should still power up, do you have 230V at input? 5V standby OK or not?
    I had some guy pull cable from inside so screen did not appear smashed, luckily did not pay much for that.
    • wreksta
      • Aug 2013
      • 508
      • england
      230V how am I measuring that had a bad experience measuring ac direct lol
      get nothing no 5v no anything it has to be this rocker that's missing
      it may have been fused I don't know
        Pictures? Use AC range on meter to measure AC.
        If you are not confident around mains AC voltages please get someone else to test or watch you while you do so. It's not worth getting electrocuted over a TV!
        • Clydeuk
          • Jan 2012
          • 193
          some cheapo sets have a single pole switch connecting to the power supply (some vestel chassis do), in that case all that's required is to jumper across that. You need to know your way round the primary side I agree get someone else to test if you're not confident, mains voltage isn't something you want to mess with.
            Sometimes the switch plugs into the ZERO WATT connection on the power board.
            • wreksta
              • Aug 2013
              • 508
              • england
              hi I have retested everything again with another good power supply and can tel you I have 5v standby only no other voltages
              I think this is a case of the power needs to be switched on
              any ideas
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                what power supply number is it?
                • wreksta
                  • Aug 2013
                  • 508
                  • england
                  mlt199tl l2 rev a
                  • wreksta
                    • Aug 2013
                    • 508
                    • england
                    does anyone have the service manual for this tv
                      This schematic of power board may be close
                      http://www.tgohome.com/ServiceManual...&Search=Submit
                      • wreksta
                        • Aug 2013
                        • 508
                        • england
                        still this tv will not power im going out of my mind here
                        2 power supplys both work
                          Have you even got 230V on the input to the board?! How about some pictures?
