sony kdl-40z5100 14 blinks
  • freakaftr8
    • Oct 2012
    • 3743
    hey guys so I picked up this TV today and when plugged in no lights no back lights no screen but it shuts off with the original 13 blink then a 14 link error code I checked the pins and inverter error is getting 1.9 volts BL error is 0 all other voltages are there I read on the forums about other similar TVs but I cannot find this model I know that 14 blanks means LCD panel air but I can't determine what's going on all fuses check out good on t-con board and main board and power supply.
    I want.to try to power up the back lights because that is zero volts but what I apply 3.3 votes to it or what I short backlight on to ground?
    Re: sony kdl-40z5100 14 blinks
    If the T-CON does not get the 12V feeding it, then it will give you the error. Check the DC voltage at both ends of the fuse of the T-CON board with ref. to the chassis ground to see what you have. The error codes may not apply t this chassis, Ii cannot find the serrvice manual for this model yet.
    • freakaftr8
      • Oct 2012
      • 3743
      Ok that makes sense. There are like 6 or 7 fuses in the tcon all test good. But ill check for 12v input to tcon.
        "There are like 6 or 7 fuses in the tcon" That can't be right.
        • freakaftr8
          • Oct 2012
          • 3743
          Im serious. There is. Ill take a pic later
          • freakaftr8
            • Oct 2012
            • 3743
            I checked. Yes im receiving 12v on the tcon.
            • freakaftr8
              • Oct 2012
              • 3743
              Ok im not getting any pri_vcc 12v to the inverters.
              • freakaftr8
                • Oct 2012
                • 3743
                http://i845.photobucket.com/albums/a...ps101ed65d.jpg
                http://i845.photobucket.com/albums/a...ps70c56d75.jpg
                http://i845.photobucket.com/albums/a...psb940eaaf.jpg
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Also there is no voltage to backlight on no voltage to balancer error but there is 1.9v on inverter error. Groynded it and still same issue. Tcon is receiving 12v and there is bo power on the big wiires to the inverters. No 12v on the yellow wire or no pfc out 395v.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Scratch that. There is pfc and 12v going to the inverters. Had to use pfc ground to measure. Thinking bad mainboard
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Ok heres the tcon lower half. You can see right off the bat 5 fuses so far.
                      http://i845.photobucket.com/albums/a...ps89b5af07.jpg
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        okay I figured it out I took a heat gun and started heating up the t-con board TV immediately came on perfect picture now I just have to figure out what are the t-con board is bad most likely a capacitor
                          Holy cow, that is one big T-CON board with about 9 switching power supplies on board. I would try heating those two Lytics SMD on the left side first. I am not sure how good your meter with frequency counter function, you can try to see what you read right at the tow legs of each caps.
                          I use my meter to locate bad caps on the logic board using my Fluke.
                          https://www.badcaps.net/forum/showth...+cap+frequency
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Yea it is.
                            Well here's where the problem in lies.
                            The left ic has to be heated for it to turn on. These pick up off the lvds cable on the tcon.
                            http://i845.photobucket.com/albums/a...ps5077d5bd.jpg
                              Hmm, need to look up the spec to see what they are for.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Here they are. They are lvds repeaters.
                                https://www.thine.co.jp/en/products/...63LVD1027.html
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Looks to have a ldo regulator and the decoupling cap I have a feeling is bad.
                                  http://i845.photobucket.com/albums/a...ps99d43610.png
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Well the decoupling cap is good. Here is a close up of the ic pinout. Im getting good vdd. Im thinking it would be cheaper to replace the tcon than repair it.
                                    http://i845.photobucket.com/albums/a...psb0a6d796.png
                                    • iglitare
                                      by iglitare
                                      09-04-2025, 07:13 AM
                                    • kca
                                      by kca
                                      Hello all ~
                                      08-31-2025, 06:38 AM
                                    • thelankanguy
                                      Sony KD-55X9000F TCON Issue
                                      by thelankanguy
                                      The TV shows a black screen with no image.
                                      TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                      Later both ribbons were disconnected and TCON voltages were tested.
                                      12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                      There is also a short to ground in this circled inductor.
                                      Is this a TCON issue or something else ?...
                                      12-13-2024, 12:27 AM
                                    • GoodCapDude
                                      Sony XBR-75X940E intermittent 6 blinks error code
                                      by GoodCapDude
                                      Hi everyone. First post on Badcaps!
                                      I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                      09-20-2025, 06:07 AM
                                    • bbrain
                                      Sony KD-55AG9 TCON?
                                      by bbrain
                                      I have this problem with my Sony 55' AG9.
                                      It flashes 4x.
                                      I have found the service manual, and seems it is the TCON.
                                      Before I buy a TCON can someone check the vid?
                                      Thanks in advance!...
                                      09-19-2024, 10:50 AM
