Samsung Plasma PN50B400P3D Won't Power Up.
  • photoeye
    • Dec 2013
    • 8
    When I power the TV on I hear the standard double click, followed by a faint 'tic tic tic' noise from the PSB and then double click and power off. Nothing shows up on the screen. Red light on front of TV lights during power up attempt as well as the green light on the control board.
    All boards appear to be very clean with no visual signs of trouble that I can find so far. Caps look great. Back of boards look good as well (haven't pulled out x main yet).
    After doing some reading, tried powering up the TV without the Y and X main connected. Like many others, I got the samsung chime and TV appeared to stay powered on even though there was no picture. Hitting the power button triggered another chime and TV powers down. Tried the same test with just Y Main attached and get same original result (couple clicks then gives up).
    Because of this test I thought I had narrowed the problem down to the Y Main. Not sure if that is the case or not. I used my multimeter to test the 'things' (sorry, It's getting late) attached to the heat sinks and got some crazy results. I'll attach my chart below. The diagram represents the two heatsinks on the board and the readings I'm getting across all leads.
    Not sure what it all means. Would love some advise. I'm new to this.
    Thanks in advance.
    -Jason
    https://www.dropbox.com/s/ot3kihpo0pl7sqx/Ymaintest.jpg
  • capkid
    • Oct 2010
    • 1339
    Re: Samsung Plasma PN50B400P3D Won't Power Up.
    Your results seem a little odd. I've found that these parts usually fail completely short (0.000). I'd figure on a replacement Y-main. Personally, I'd replace the Y-buffer, also. Be sure to check the X-main.
    LG Plasma Mal-Discharge Correction Service
    • photoeye
      • Dec 2013
      • 8
      Thanks Capkid. There is another active thread for the exact same TV with nearly identical symptoms. The OP has replaced the Y-main, X-main, then control board and finally PSB with no change in behavior to the set. Hoping to pinpoint the problem before throwing parts at it. The thread has now gone completely cold.
      I'm going to get my hands on a better MultiMeter and test the board again.
      • capkid
        • Oct 2010
        • 1339
        I think it's wise to try a different meter, because the readings look strange to me.
        • Samsungtv
          • Apr 2015
          I too have the same issue with my Samsung pn50b400p3dxsa. Has anyone found a solution. If I unplug the power supply to the Y-Main the tv turns on and off, with no picture.
          • bcstedt
            Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
            by bcstedt
            Just starting to crack into this one and wanted to get the ball rolling.
            At power on (plug in), power light on, relays click, repeat (sometimes)
            After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
            Removed Y-Main for inspection and testing
            This pic from:
            PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
            12-15-2023, 10:30 AM
          • Cooperr
            Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
            by Cooperr
            I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
            The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
            10-21-2025, 01:11 PM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
