Vizio XVT553SV Power up problems
  • avia581
    • Nov 2013
    • 8
    Hello everyone. I have had this TV for a few years and it has given me a lot of trouble. It has been replaced by the factory once while under warranty and then a year after it was replaced that unit went black. I had a company repair the TV. They installed a new main board and I think the T-con. Now it has gone black again. It stays in the standby mode and will not fully power up. The little vizio light on the front stays an amber color and pulse's to a dim amber after hitting the power switch. It should light up bright white. Does anyone have any ideas for me. Thanks in advance.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Vizio XVT553SV Power up problems
    Open the tv up and take pictures of each board individually, one up close of each connector on the power supply board so we can see any markings and one of the entire back of the set.
    Do you own a multimeter?
    • avia581
      • Nov 2013
      • 8
      I do own a multi meter. I have also attached the photos. Thank you.
      • newtothis
        • Mar 2013
        • 1556
        • england
        Connector CN202... DMM set to 20VDC, Red probe into the 3rd wire (red, PIN 3) connection (just push into top of connector where wire goes) and black probe to chassis (screw hole is good)
        Reading before and after you try powering up the set?
        • avia581
          • Nov 2013
          • 8
          It reads 5.17v before and after the switch is pressed.
          • newtothis
            • Mar 2013
            • 1556
            • england
            CN201, Same as before on pin 1, 4 and 5
            • avia581
              • Nov 2013
              • 8
              The readings were the same for before and after pressing the power switch.
              Pin 1: 2.1v
              Pin 4: 5.17v
              Pin 5: 5.17v
              • newtothis
                • Mar 2013
                • 1556
                • england
                Do you have a 470 - 1k resistor at hand?
                • avia581
                  • Nov 2013
                  • 8
                  I have 2 resistor at hand. They read
                  9.95K and 3.3K Would they work?
                  • avia581
                    • Nov 2013
                    • 8
                    I also found ones at
                    0.465k and 24.0k
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      Can you take a closer picture of the connector from the PSU to the mainboard please
                      • avia581
                        • Nov 2013
                        • 8
                        Here is a closer pic
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          Ooo just realized this is an LED lol... Let me just check something.
                          Tom66 which pin is it to force this PSU on? Still same rating resistor to do so? Take it 465 is Ok too?
                          P.s Tom clear your PM's out LOL.. No one can message you
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                            09-06-2024, 05:59 AM
