Samsung PN50A450 - No Power
  • steveh_131
    • Nov 2013
    • 33
    This is my first question on these forums although I have done hours of research.
    I bought this plasma TV on craigslist for $50. The owner said it was hard to turn on and he didn't know what was wrong with it. I figured I would take a stab at repairing it. I did a lot of research and found that there are a few bad capacitors on the power boards of this model, and Samsung actually did a recall.
    I brought it home and plugged it in and it does nothing. No red standby light, no clicking, nothing. This isn't really consistent with the problems addressed in that recall. I ordered a new power board for it anyways, thinking that must be the source of the problem. It was used but supposedly tested and functional. I replaced it and still nothing.
    I checked the three fuses on the power board, and two glass fuses on two other boards and they all show continuity.
    It gets 110V AC at start of the power supply, and I see a higher DC voltage at some of the other power supply fuses.
    Here is an overview of the layout:
    Any ideas would help, or even some troubleshooting steps. Thanks!
    Steve
    Re: Samsung PN50A450 - No Power
    Can you get a picture of the label near the connector between the main board (with HDMI ports) and the power board?
    • steveh_131
      • Nov 2013
      • 33
      Here's a few:
      Do those help? I guessed you were talking about the label directly to the right of the power board, but I wasn't sure so I took a few.
      Thank you so much for your help, Tom!
      • newtothis
        • Mar 2013
        • 1556
        • england
        Should be this one Tom
        • steveh_131
          • Nov 2013
          • 33
          Or this is printed on the actual power board by the connector to the main board:
          ETA: Snapped a better one
          • newtothis
            • Mar 2013
            • 1556
            • england
            If you look on the PSU, look at the connector the with the cable that goes to the main board... you will see near that connector a reference for the voltages of the connector. Take a photo of that
            *** Nevermind You posted while i was writing that LOL! ***
            • steveh_131
              • Nov 2013
              • 33
              Does that show everything you need? I'll gladly take any more that would help.
              Steve
              • PlasmaRon
                • Nov 2013
                • 40
                It's hard to see from the picture, but do a couple of caps at the top of the Z board have bulges? (Top right of picture)..
                Would you expect the standby power supply might be bad or loaded down?
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  DMM set to 20VDC, black probe to chassis (screw hole works well) red probe to the STBY PIN, So in orientation with that picture.. 2nd down from top right.
                  Whats the reading?
                  • steveh_131
                    • Nov 2013
                    • 33
                    I don't see any bulging caps. I'll look again more closely.
                    If I'm reading the STBY pin correctly, it gets 5V.
                    That is with the cable unplugged, right?
                    Steve
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      Yeah that's fine, so we have the standby voltage.
                      Next put red probe to PS_ON, Same orientation, Top right... watch the reading when pressing power switch.
                      Mainboard plugged in this time, You can put the probe into the top of the connector at the wire... it will touch the contact
                      • steveh_131
                        • Nov 2013
                        • 33
                        It stays steady at 3.7V whether I'm pressing the button or not.
                        It has these weird buttons that I assume are touch sensitive? They don't actually press in. I tried the one on the tv and I tried the remote as well, neither seemed to change that voltage.
                        Steve
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          So PS_ON has a constant ON signal.
                          To me that indicates a short on the main board... Tom66 and Budm have more experience with plasma's than me so I will let them chime in on this and see if they agree.
                          Can you check each pin on that connector and post back voltages. ta
                          • steveh_131
                            • Nov 2013
                            • 33
                            Interesting. So when the main board is unplugged from the power supply board, the standby is on. Then when I plug in the main board, the standby goes to zero. This does suggest an issue with the main board I suppose.
                            I'll test the rest of them in a bit and post the voltages.
                            • steveh_131
                              • Nov 2013
                              • 33
                              The PS_ON and STBY were the only two pins that seemed to have voltage. 2-3V.
                              I had a really hard time getting the probe in to the top row of pins, so I don't know how accurate those measurements would be, but they all seemed to be zero.
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                Without the PSU in the ON state they should all read zero except the STBY pin... Once the PSU received the on signal from the main board the other voltages should become present. Generally the PSU will send a voltage >2.5v to the PS_ON pin to initiate the PSU... as it stands the voltage is constantly >2.5 indicating a fault.
                                • steveh_131
                                  • Nov 2013
                                  • 33
                                  Ok. That makes sense. So does the main board need to be repaired or replaced? Any troubleshooting steps to take beyond this?
                                  I really appreciate all the help so far!
                                  • newtothis
                                    • Mar 2013
                                    • 1556
                                    • england
                                    Will at this point have to pass you to Tom66 and budm.
                                      Could be bad cap on standby circuit. One way to test.
                                      Unplug power to main board connector from main board end.
                                      Wire jumper between PS_ON and any GND.
                                      Wire jumper between VS_ON and any 5V STBY.
                                      Follow steps here: https://www.badcaps.net/forum/showpo...61&postcount=2
                                      (LVDS runs between main board and the control/logic board.)
                                      You should get a cycle of test patterns on the plasma panel if the only fault is the main board.
                                      • steveh_131
                                        • Nov 2013
                                        • 33
                                        Let me clarify before I run this test, if you don't mind. Steps:
                                        1. Unplug power-to-mainboard connector AT the mainboard.
                                        2. Wire jumper between PS_ON and GND - On the power board? Or the main board? Should I do this on the end of the cable that was unplugged from the main board?
                                        3. Jumper between VS_ON and 5V STBY - Where is VS_ON? I don't see it on the list from the power-to-mainboard connector.
                                        4. Unplug the LVDS
                                        5. Turn on tv
                                        Thanks again for your help!
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • mrtek
                                          Samsung UN43NU6950FXZA No power
                                          by mrtek
                                          Hi
                                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                          Main fuse = OK
                                          Back light LED = OK. Power them with aux power source
                                          LED output = OK 156V
                                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                          07-20-2025, 08:06 PM
                                        • hill01
                                          Samsung UE75MU7009TXZG Endless Power Cycle
                                          by hill01
                                          Hi everyone and thanks in advance for any help I might get here
                                          My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                          About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                          Since a few days, the TV won't turn...
                                          11-17-2021, 02:52 PM
