samsung le32r87bd loses backlight after 3 secs
  • charlierfc
    • Mar 2013
    • 93
    • scotland
    Re: samsung le32r87bd loses backlight after 3 secs
    hi tom with my meter set to 220ohhms and ned to the cap and pos to the stated led,i get no reading?
      No that's fine, was just hoping that it would be that simple. You will need to test the other nearby capacitors around it (the beige things are capacitors) until you find the one attached to pin 15. One of them will be.
      • charlierfc
        • Mar 2013
        • 93
        • scotland
        only reading i can find is from this cap to the leg stated,although the reading is breif,might be my shakey hands!
          Can you try macro mode with flash then? Could also try putting a wire from pin 15 to ground to disable the timer, if you think you can do that.
          • charlierfc
            • Mar 2013
            • 93
            • scotland
            ill give it a try in the morning,thanks for all your help
            • haydon
              • May 2012
              • france
              #26
              Thanks for great article, would like to know when you say one can disable the protection by a solder jointits bewteen which pin and WHERE please. thanks Haydon
              • jjanssen7
                • Nov 2012
                • 252
                Follow up question. I have the exact same inverter board, with same problems. The capacitor in question is the one right opposite pin #15. When I ground pin #15 and power up the TV, the inverter comes on and stays on as long as that pin is grounded.
                Here is my question. all bulbs are working fine, and my inverter transformers test similar to above (1.23 @ 20kohm). Is there a fault in the protection circuit?
                • hedgeville
                  • Feb 2015
                  • 3
                  • United Kingdom
                  #28
                  Hi fairly new to this game....
                  I have a samsung LE32R87BD whcih appears to of had two problems the usual slow to come on and finally not even come on which as been resolved by the replacement of the electrolytic caps on the cold sides on the PSU board (BN44-00156A)
                  I have a TV that now comes on and shows me a great picture for 1-2 seconds then the back-light goes off. I can still see the image by shining a bright light on the panel. The audio is working beautifully.
                  I have followed the details on this thread through and I am now stuck with no further options....
                  • The Inverter fuse is fine.
                  • Outputs on all transformers on inverter board ~1.2M ohm therefore fine.
                  • Seems to have a good steady 24v going to the inverter board
                  • 3.6M Ohm between 0z9966sn pin 15 and c121 as per post #20
                  • Jumpered pin 15 & 16 and the back-light didn't come on at all not even for the 1-2 second flash as per prior to earthing pin 15
                  I have therefore undone pin 15 to ground and the flash on for 1-2 secs has returned.
                  This is now doing my head in
                  I really dont want to ditch this great Tv so any help is much appreciated.
                  • hedgeville
                    • Feb 2015
                    • 3
                    • United Kingdom
                    #29
                    Have now tried to reset the EEPROM on the main board with no further success as I have read that the EEPROM files can become corrupt when the capacitors deteriorate. Therefore I reset the EEPROM to try and rule this option.
                    This process made absolutely no difference to the back light flashing on for 2 seconds.
                    Can anybody suggest anything to check or try next?
                    • lewis154
                      • Dec 2016
                      • 4
                      I have a Samsung 32" LE32R87BD but the problem I have is, one or 2 of the backlight bulbs under the inverter board are damaged, one bulb has snapped the top off. Is it possible to replace these ? how tricky is it to get at these ? (I am fine soldering small) and were can I buy the actual them from in the UK as I am struggling to find any information on the bulb itself for this particular model.
                      • lewis154
                        • Dec 2016
                        • 4
                        I am going to convert the CCFL lights to LED lights on a LE32R87BD. If anyone can help with an LED light kit that would be great
                        • dal743
                          • Jul 2017
                          • england
                          #32
                          I have had some success with fixing this. After replacing all 6 caps with the green/blue stripe painted on and still no back light, I did the hair dryer thing. Looking at pic 3 of post #3 I held it over the two coils and on switching it on again it stayed on - so far so good.
                            09-07-2024, 05:50 AM
                          • C152Heavy
                            by C152Heavy
                            Summary for TL-DR readers:
                            • VCC pin (18) of PFC...
                            01-11-2023, 02:53 PM
                          • sansanpartida
                            Samsung QE82Q70RAT no backlight
                            by sansanpartida
                            Hi everyone!
                            Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                            My issue: No backlight.
                            Model: QE82Q70RAT
                            Type No: QE82Q70RAT
                            The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                            So hopefully, I can fix this cheaper.
                            05-22-2024, 06:56 AM
                          • howardc64
                            Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                            by howardc64
                            TV was fixed just after removing Samsung's rear snap cover.
                            This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                            Maybe PSU->backlight connector didn't have a good contact?...
                            07-23-2025, 12:34 AM
                          • howardc64
                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                            by howardc64
                            • Prior owner tried a replacement main board. No difference.
                            • Samsung 2x red blinking standby LED = panel fault
                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                            07-19-2025, 10:54 PM
