Xvt473sv mainboard compatable with SV421xvt?
  • topfli8979
    • Oct 2012
    • 311
    I know its a long shot but I have a Vizio 47 with busted screen and a vizio 42 with good screen needing mainboard. The mainboards on both tv's are identical in every way,plugs,components. Only difference is color,47 main is blue and 42 is green. And the part #'s are different of course. My question is will the 47 main work in the 42? Worth trying? Gonna fry anything?
  • topfli8979
    • Oct 2012
    • 311
    Re: Xvt473sv mainboard compatable with SV421xvt?
    • topfli8979
      • Oct 2012
      • 311
      Wanted to update the post, board arrived in mail today. Tv now works great and operates as it should.
      • J doug
        • Feb 2014
        • Usa
        topfli8979, that is awesome!! I was told that even though the board layout is very similar, to expect alot of distortion on the screen... do you see any visual effects at all???
        • Devonavar
          Vizio M43-C1 - How closely do I need to match the mainboard number?
          by Devonavar
          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
          So, I've ruled out the PSU for now.
          The reboot loop...
          08-14-2022, 08:46 PM
        • maricm
          Vizio P65 with P55 mainboard
          by maricm
          IH all, Got this vizio tv P65-E1 from FB marketplace hoping to be able to reflow mainboard as selerrstated that it was diagnosed with bad mainboard. However they must have tried to repair tv by putting another board in and they put P55 board in .
          Tv starts and responds to remote but screen does not look right , It looks like low resolution with some image ghosting. Now not having original board I dont know what to order ? Any advice how to figure out what exact board fits this tv ?
          And another question Would it be possible to adopt this board to this tiv by chagning eeprom or tcon...
          04-23-2024, 08:25 AM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
