LG 60PS11 (plasma) no picture
  • j_rigsby
    • Nov 2013
    • 20
    Re: LG 60PS11 (plasma) no picture
    Ok, just took out buffer boards instead. Was easier. Both Vsc and -Vy voltages dropped to 0.04 VDC ish.
      That's with the power supply connected to the Y-sustain?
      • j_rigsby
        • Nov 2013
        • 20
        Yes it is. All power connected, buffer boards removed. I will leave on for ten minutes and check agin. I will also double check voltage to Y-SUS board
        • j_rigsby
          • Nov 2013
          • 20
          Checked again. 196 VDC coming in on VS, 68 on VA, nothing on test points for -Vy and Vsc.
            This would seem to indicate your Y-sustain is faulty, then.
            • j_rigsby
              • Nov 2013
              • 20
              Ok I will order one and replace it. I will keep you posted. Thanks for the help.
              For future reference, should the voltages at the test points for -Vy and Vsc be similar to VA or VS voltage? Or what is the relationship between the two?
                -Vy is typically in the -100V to -200V range, Vsc is typically in the (-Vy+50V) to (-Vy+150V) range. The exact values are listed on the plasma panel sticker and indicated in the service doc I linked you.
                • j_rigsby
                  • Nov 2013
                  • 20
                  Ok real good. Thanks again for sharing your knowledge. Much appreciated.
                  • Jeff Pepin
                    • Jun 2014
                    • 103
                    • CANADA
                    #29
                    Hi i have the exact same trouble with exact same panel . But seems like y-sus of this tv are rare now . Mine dont energize at al but have sound , y sustain humm like normal one , z- sustain humm too and i can hear the noise change if i pop up osd !
                    All voltages look good exept VSC and -VY who are both ~4/10V)
                    I have dismounted all heatsink on y sustain than checked all t0-220 with an atmega 168 based device tester ( ebay)
                    on heatsink labeled HS401
                    Heatsink contain 7 x 51n25 (51A 250v)
                    4 of them reported as NE-MOS
                    3 reported as diode (farted)
                    (Dont have any 51amps so i have replaced all 7 by 7x irf14229 (38A) so i have added 3 more on an extra heatsink
                    Heatsink HS805
                    Contain 2x RF2001 and 4X 45F122
                    All 4 45f122 reported as capacitor ( farted)
                    Replaced by 4 x 45g127
                    Heatsink HS 804
                    Contain 2xRF2001 and 4x 45F122
                    All parts on it was good
                    HS702 AND HS703
                    each contain 4X RF2001 and 2X 45f122
                    All parts on it reported good
                    The last heatsink contain 2X K3453 and reported good
                    All big surfacrmount diodes report good in diode mode DMM
                    All resistors at gate of transistors are good
                    I will update further the progress of my work
                    • Jeff Pepin
                      • Jun 2014
                      • 103
                      • CANADA
                      #30
                      there it is '' the thing''
                      • Jeff Pepin
                        • Jun 2014
                        • 103
                        • CANADA
                        #31
                        also with both y-buffer boards removed VSC and -VY voltages are ~4/10V
                        i will test most regulator on the board today and make an update
                        • Jeff Pepin
                          • Jun 2014
                          • 103
                          • CANADA
                          #32
                          what i have checked at this time in this sector
                          in red its relults with tv plugged and on
                          in yellow its reading with setup OFF and unplugged
                          • Jeff Pepin
                            • Jun 2014
                            • 103
                            • CANADA
                            #33
                            Im not just sure if its a good idea to put my multimeter on dc and probe my IGBTs while the set running to see whish section does not work maybe i will find whos not pushing current or simply not switching on
                            Like black probe on the frame and red probe on g/d/s
                            • heavymachines
                              • Mar 2011
                              • 1028
                              You can test without power. In diode mode with dmm.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                #35
                                What is the part number for IC906
                                • Jeff Pepin
                                  • Jun 2014
                                  • 103
                                  • CANADA
                                  #36
                                  The part is labeled RSS090
                                  • Jeff Pepin
                                    • Jun 2014
                                    • 103
                                    • CANADA
                                    #37
                                    Oh wow a switching power mosfet , and my vsc not switching on..
                                    • Jeff Pepin
                                      • Jun 2014
                                      • 103
                                      • CANADA
                                      #38
                                      Yess in fact i have removed all heatsink with parts on it then tested each one , replaced 4X 45F122 blowed open and reported as a capacitor and 3x 51n25 blowed open and reported as a diode between drain/source .
                                      All transistors are actually good , there is a failed gate driver on this board and i dont know where , so if i probe source /drain in each stage of the sustain i will be able to determine wich one have no power or simply not switch on .but i fear the power in these board lol i dobt want to toutch the drain of an igbt and see a electric ball of light
                                      • Jeff Pepin
                                        • Jun 2014
                                        • 103
                                        • CANADA
                                        #39
                                        man thanks ive just do some readings with black probe on frame , and it look like this mosfet are not switching on ,
                                        if im ok in knowledge with a working fet ,when applying 2v to the gate it will switch on and the 5.0V from the drain will pass thru the source right ?
                                        in this case the 5.0V not pass thru ,
                                        option a 1,9V is not enought
                                        option b the switch is toast
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                        • KYBOSH
                                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                          by KYBOSH
                                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                          No picture but you hear the TV static (white noise) playing loud and clear.
                                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                          But it seems they didn't get too far and just left it.
                                          When I first took a look I was amazed at how pristine the inside looked.
                                          Its as if the TV had been in a time capsule.
                                          Caps looked like they were just pulled off the self.
                                          Copper coils had no sign of corrosion on...
                                          02-01-2023, 11:10 PM
                                        • acedogblast
                                          Power supply for main amp blows fuses after replacing filter caps.
                                          by acedogblast
                                          Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
                                          I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
                                          I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
                                          02-27-2023, 05:11 PM
                                        • gavric
                                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                                          by gavric
                                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                          When i click video to start playing picture goes black(like when you change...
                                          09-02-2021, 08:55 PM
                                        • bffargo
                                          2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                          by bffargo
                                          LG 60PB66550 NOV 2014
                                          PSU: EAY63168603
                                          PCB: EAX65359531 2013.11.01 Rev:1.0
                                          Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                          Symptom:
                                          While watching, just went black and started clicking relay every few seconds.
                                          Initial diagnosis:
                                          Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                          Deeper diagnosis:
                                          Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                          09-09-2022, 07:34 PM
