LG 60PS11 (plasma) no picture
  • j_rigsby
    • Nov 2013
    • 20
    No picture or OSD. Seems like it wants to energize, screen breifly lightens up when initially turned on. Lasts maybe 1/2 second, then total blackness.
    Sound is good. Menu and input buttons work (I can change inputs and get sound from multiple devices connected, but no picture)
    From what I have ascertained thus far from reading tomcat66's wonderful troubleshooting guide is that I should be checking the fuse(s) on the Y main for continuity.
    I have found the block diagram in the resources provided on this site, although I am having trouble identifying where exactly the fuse(s) is/are on the Y main. I haven't pulled the back off the unit yet; I will be doing this tonight (hopefully they are obvious). Thought I would post this to gather some support for the steps that lie ahead and to also thank those who share their vast knowledge with us who are new at this.
    Hopefully I can get this figured out. I am curious about getting parts for this unit once I figure out what the problem could be. I know tomcat66 mentioned something about replacing the entire Y main if it were found to be faulty as a matter of convenience over troubleshooting individual components. Where does one order the parts? Thanks for the help.
    Re: LG 60PS11 (plasma) no picture
    It's tom66
    As for the problem, it sounds like possibly a main board fault, given the brief screen energisation. Do you own a digital multimeter to make some tests?
    Ordering parts: shopjimmy (new from scrapped sets, tested), tristate module, LG directly (more reasonably priced than you'd expect), eBay, etc.
    • j_rigsby
      • Nov 2013
      • 20
      Sorry Tom. Not sure where I got the cat from.
      Anyway, yes I do own a multimeter. Got the back off and found one fuse right where the power bridges into the main board. It was good. Didn't find any other obvious fuses anywhere amongst any other circuitry.
      What tests should I be making next? I have the block diagram handy.
      • j_rigsby
        • Nov 2013
        • 20
        So I did a little bit of research. Just doing some observation work as I do not wish to destroy things that are not ruined already.
        Green led on logic board does not flash evenly after start up. The sequence seems fine, as in one led goes solid, other flashes about once per second. Then, flashing led (after two consecutive flashes one sec apart) does the following: long flash short flash, long flash short flash. two full seconds, then it repeats the same way.
        Looks like an error message to me, yet I cannot find data anywhere on error sequencing.
        • j_rigsby
          • Nov 2013
          • 20
          Anyone have any ideas on this? Any assistance would be much appreciated.
            Would you be able to use a multimeter to check the Vs, Va voltages?
            • j_rigsby
              • Nov 2013
              • 20
              Tested connector blocks P811 and P812 (x and Y)
              VS = 197.7 VDC on all pins
              VA = 68.5 VDC on all pins
              5.12 VDC on 5V pin
                OK, on the back of the plasma screen metal plate, there is a model printed like PDP50K1##### near the LG Electronics information. What is this model number?
                • j_rigsby
                  • Nov 2013
                  • 20
                  P 813 and 814 connectors all have correct labelled voltages as well.
                  • j_rigsby
                    • Nov 2013
                    • 20
                    Model is PDP60H30001
                      Great, I have PDP60H3 manual
                      (search for "60H3")
                      This manual indicates how and where to test Vsc and -Vy. Please check these voltages.
                      • j_rigsby
                        • Nov 2013
                        • 20
                        -Vy is 2.1 to 2.3 VDC
                        Vsc is 2.8 to 3.1 VDC
                        Obviously too low. This means the Y main is buggered?
                          Please see what happens to those voltages if you isolate them from the Y-sustain.
                          • j_rigsby
                            • Nov 2013
                            • 20
                            Not sure what you mean here tom. The voltages were taken directly on the Y sustain board. How am I supposed to isolate them? Unplug the Y sustain from the power board? Or do you mean to isolate the Y-sustain from the logic board?
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              Disconnect Y-sus from PSU and test the pins
                              • j_rigsby
                                • Nov 2013
                                • 20
                                I disconnected the LVDS ribbon cable and jumped pins 1&2 on the AUTO GEN and did not get a test pattern on the screen.
                                I also disconnected the cable from the Y-SUS to the board directly underneath (X-Drive left?) and tested -Vy and VSC. Both were less than.05 VDC. Tried testin with logic control board disconnected, same result.
                                • j_rigsby
                                  • Nov 2013
                                  • 20
                                  PSU = Power Supply = SMPS?
                                    Uh, my error. I mean disconnect the Y-buffers from the Y-sustain. Doh. Do the voltages rise?
                                    • j_rigsby
                                      • Nov 2013
                                      • 20
                                      If yes, then both -Vy and VSC are 0.005 VDC after disconnecting from power supply.
                                      • j_rigsby
                                        • Nov 2013
                                        • 20
                                        Will try that, but looks like I may have to unscrew Y-SUS from frame, no?
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                        • KYBOSH
                                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                          by KYBOSH
                                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                          No picture but you hear the TV static (white noise) playing loud and clear.
                                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                          But it seems they didn't get too far and just left it.
                                          When I first took a look I was amazed at how pristine the inside looked.
                                          Its as if the TV had been in a time capsule.
                                          Caps looked like they were just pulled off the self.
                                          Copper coils had no sign of corrosion on...
                                          02-01-2023, 11:10 PM
                                        • acedogblast
                                          Power supply for main amp blows fuses after replacing filter caps.
                                          by acedogblast
                                          Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
                                          I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
                                          I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
                                          02-27-2023, 05:11 PM
                                        • gavric
                                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                                          by gavric
                                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                          When i click video to start playing picture goes black(like when you change...
                                          09-02-2021, 08:55 PM
                                        • bffargo
                                          2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                          by bffargo
                                          LG 60PB66550 NOV 2014
                                          PSU: EAY63168603
                                          PCB: EAX65359531 2013.11.01 Rev:1.0
                                          Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                          Symptom:
                                          While watching, just went black and started clicking relay every few seconds.
                                          Initial diagnosis:
                                          Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                          Deeper diagnosis:
                                          Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                          09-09-2022, 07:34 PM
