Hi me again!! New problem with PDP42TV006
  • FritzCT
    • Nov 2013
    • 30
    • england
    So I recently replaced the power board and everything was working fine.
    That is until, I hot plugged the aerial back in. I heard something short and the set went dead. Now I get nothing when I power on, not even the led's on the back of the power board. I checked the fuse in the plug and the ones on the power board but still nothing.
    I'm hoping this is a known problem and has a known fix, preferably not to complicated. If it's another new board then I think I'm going to cut my loses and just replace but I'd like to know your thoughts first.
    Many thanks (again)
    Fritz
    EDIT: Power board is LJ44-00068A
    Re: Hi me again!! New problem with PDP42TV006
    It is possible your new power board is defective, especially if for example it was damaged in shipping or during removal.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • PNI E.
      Dyson v15 problem with the dust detector board
      by PNI E.
      Hi guys, I have a Dyson v15 that didn’t work. The battery blink 10 times. If i disconnect the cable of the dust detector board, the Dyson turn on but after some seconds stop because didn’t feel the flow of the air because I disconnected the bird sensor, if I connect the Dyson is death. I notice the big mosfet I think with 3 pins. If I check the mosfet I have a short circuit from the center pin ne the left pins…so I think that s the problem or I wrong? The problem I can’t understand what type of mosfet is….someone can help it s hard to find. New board...
      10-02-2025, 10:18 AM
    • huj3r
      Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
      by huj3r
      Hi there!
      I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
      Photo of the situation after the black shadow dissipates:
      After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
      I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
      > This indicates HFR Communication error. [ HFR Communication...
      08-15-2023, 10:55 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
