Sony BU board question
  • Mongor62
    • Sep 2013
    • 83
    • California
    I Have a KDL-52W5100 and i have a thread that has been forgotten and i apologize over starting a new thread over this but my question is simple.
    I am looking at the service manual i found and it says to use "A-1734-658-A" and i went to shop jimmy and it showed that model number board to be used in this TV however when i looked at the board in the actual TV it was a "A-1671-682-A" and this looks to be used in the XBR9 a different TV and 65 inch models as well, so should i look to get another 1671 or a 1734??
    Re: Sony BU board question
    You should order the board as in the TV, as long as you're sure that's the original.
    • Mongor62
      • Sep 2013
      • 83
      • California
      I am i would say like 90% sure it is but i honestly have no clue, its my buddies TV and he didn't get it new. I included the manual i found to show my point of reference(pg 78).
      • R_J
        • Jun 2012
        • 9535
        The number in the manual will not match whats on the board itself, that number is usually the number of the blank pc board. Watch the video on shopjimmys site http://www.shopjimmy.com/sony-a-1734-658-a-a-board.htm
        • Mongor62
          • Sep 2013
          • 83
          • California
          I have seen that video maybe 3 times and am well aware of how they take model numbers and the Service Manual does have the right stuff in it not just some random stuff. It is more so a question of what all will work and i have been reading and what i have come to the conclusion of is what model TV is the BU board flashed for.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • delpiero3
            Sony Vaio SVS MBX-261 board failure
            by delpiero3
            Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
            Nevertheless, let's say, i don't come as a total beginner.
            I have this old laptop, which suit perfectly my needs, with the...
            10-29-2024, 06:16 AM
          • huj3r
            Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
            by huj3r
            Hi there!
            I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
            Photo of the situation after the black shadow dissipates:
            After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
            I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
            > This indicates HFR Communication error. [ HFR Communication...
            08-15-2023, 10:55 AM
