Sharp LC-32D42U repair
    The power supply has no standby voltage due to bad snubber Zener diode (150V 5W) D7907 (1N5383) that shows 50 Ohms in both direction in the STBY SMPS, SMPS IC is TNY268 (https://cdn.badcaps-static.com/pdfs/...87623814b3.pdf).
    Re: Sharp LC-32D42U repair
    That looks like a Delta power supply board? What is the part # of it for future reference? DPS....
    • Makiaveli
      • Nov 2013
      • 10
      • England
      hi
      • Makiaveli
        • Nov 2013
        • 10
        • England
        Hi, i know this isnt to do with this thread an i apologise, im new here and just signed up. I wanted to post a new thread but for sum reason its not lettin me. i seem to be able to reply 2 a thread, does anyone know why this maybe?
          You can make a thread after your first reply. Check your PM inbox.
          • Makiaveli
            • Nov 2013
            • 10
            • England
            ok i feel like a idiot, just read the forum rules. apologies for clogging up ur thread bud, typical school boy error!!
              Yes, it is DELTA board.
                DPS-178AP for any search engines .
                • metropical
                  • Jan 2017
                  • 42
                  even though this is an old thread ..... perhaps.
                  I've had a bum delta ps in another Sharp LC32D42U that we have. Swapped ps today and that is the issue.
                  Last time it was the big zener D7908, but this time both D7908 and D7907 test (compare) bad. Last time I replaced the D7908 with a 10 wt instead of a 5wt, but I have misplaced notes on the 1N number and I don't know the 1N number of D7907 either.
                  I'd like to find those numbers so I can buy and replace the parts.
                  Anyone?
                  • PotShotScott
                    • Feb 2007
                    • 40
                    Found this thread searching for my TV. Found 1n5383b on Bing/Google to be in the D7907 position. If anyone does respond to this thread where is D7908 on the Delta DPS-178AP A power supply board?
                    • metropical
                      Sharp lc32d42u seems dead
                      by metropical
                      plugged in after being off for quite some time. No OPC lights. Tried flashlight test for backlight check, nada.
                      Pulled the PS and checked all diodes including the 5w(?) D7908 that was the issue last time. All diodes check OK in circuit with DVM diode test.
                      No caps look unhappy. It is 17 years old. Was gonna fix and give to my brother.
                      But is there anything else to try or is it likely met its match.?...
                      09-28-2024, 05:41 PM
                    • dkneyle
                      Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                      by dkneyle
                      This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                      Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                      02-01-2022, 02:08 AM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • abhishekkumar1902
                      Huntkey HK340-72FP SMPS shut on load above 2 amps
                      by abhishekkumar1902
                      I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
                      I have checked the following:
                      1. All output caps are OK, and all output rails read correct voltages at no load
                      2. All output diodes are OK
                      3. NTC is ok
                      4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
                      5. No short in main switching MOSFET
                      6. All other components...
                      12-18-2022, 09:52 AM
                    • sefoster
                      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                      by sefoster
                      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                      11-20-2022, 09:29 AM
